![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Oil change interval ??
I recently moved. I was living 4 miles from work and now I am 2 miles from work. That is 80 miles a month for work plus what I drive on my days off which isn't much. Let's estimate 100 miles a month (1200 miles a year) how often should I change my oil? I was thinking once a year.
In your owners manual. 6 months or 3000 miles (dino) or 5000 miles (synthetic)
so in your case you would fall under every six months. |
Drives: 07 sedan Join Date: Mar 2010
I agree with Alex, do it every 6 months.
On a side note - Cars weren't made to drive 2 mile trips exclusively. Your oil probably never reaches proper running temperature, meaning every mile you put on your car is gonna be high wear on the engine. Gas is going to sit in your tanks for 3 months minimum. Your battery and alternator will probably go faster than on a normally driven car. I'd guess you are in the 99th percentile for dollars/mile spent on tires, oil, and insurance for yaris owners. If I was in your situation, I would sell the car and get a bike. |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
And in other news, weather.com shows 43F and light rain in Waldoboro, ME right now, with heavy rain forecast for tomorrow. Last month, the temperature dipped to -1F. Then again, it's only for a few miles every day...
Anyway, this may be one of those situations where spending the 0.03 gallons involved in warming the car up once a day might make sense from an overall perspective. Or running it for a little longer once the destination has been reached. The oil, and exhaust system, etc, really do like to reach normal operating temperature on a regular basis. This kind of operation eats mufflers right up. Water sits in it continuously, rather than evaporating out, and it quickly corrodes out from the inside. -Steve |
I only average ~5k miles per year. I change my oil every 4 months. Sbergman is quite right about what this does to mufflers! Although I had my ECHO for 8 years/50k miles and the muffler was stilll good when I sold it. Fuel injection is far kinder to engines than carburation was. The rich mixture of a carbed engine at idle/low speeds makes the oil stink like gasoline. Which cant be good!
I don't think I will be riding a bike to work anytime soon. Most of my drive is on a busy 4 lane road that I wouldn't feel comfortable riding a bike on. As for letting the car warm up I park in a garage now. I guess I could go out to the garage and open the door then start the car and let it warm up. Or like you suggested keep it running awhile after I get to work.
resident senior
You could get a turbo timer to let the engine get to operating temps and not have to worry about someone jackin your ride . For example , you could start your car (whenever) , set your turbo timer for 10 minutes , turn your car off(pull key out ) and go about your business . The engine will shut off after the 10 minutes .
here are some examples http://www.vividracing.com/catalog/a...timer&x=17&y=9
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Dont run you car and waste fuel! Get a Motorbike for your commute. + I am sure you will drive to other places besides work.
#9 | |
Perspective, please? -Steve Last edited by sbergman27; 03-29-2010 at 01:03 PM. |
The argument is what to do about this drivers OCI not some strawman arguement about his/her neighbors Ford EXCURSION and how they text in the idle vehicle at the mall while Mom is shopping, with the windows up and the twin AC running. Its 2 miles. Carpool, Electric Scooter, bum a ride with an ax murderer, or, maybe ... Walk. People in my office walk 2 miles to nowhere at lunch for exercise. What a concept! BTW I was talking to the extra idling time idea, which wont raise the sump to any effective boil off temp. OP is stuck with 3mo OCI. Short drives are the oil killer and acid builder of all time. If only for commuting the OP could use 0w-20 oil and run 1/2 qt low to raise the sump temp and keep the viscosity a bit lower than honey gooo.
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Wow, there's a lot of chatter here for a simple "how often should I change my oil" question.
Use synthetic oil. Change it every spring. Enjoy. |
#12 | ||
I've not seen any separate "severe service" recommendation from Toyota, beyond the standard 5000 mile/6 month specification. So 6 months should be fine. -Steve |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
I do 6k on Mobil one syn no issues.
#14 |
What?
Yeah, if you're worried about warranty, gotta do what the manual states.
#15 | |
thats my weather, lol, not the OP's. my commute is a 25 miles one way |
#16 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
what about AMSOil that claims to have up to 25,000km before changing oil.
#17 |
#18 |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 02:55 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
