Old 03-31-2010, 01:31 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Series/Parallel Config ?
Okay i got myself into a situation to where i can get two sets of these speakers (4 speakers total ) for a decent price. My amp does 87 rms so if i ran these in series parallel i could run these at 4 ohms i shouldn't have a problem with overpowering them would i ?
These are Audiopipes btw
*3.5" Dynamic 2-Way Car Speaker
*Max Power: 90 Watts
*Rated Power: 45 Watts
*Electroplated IMPP Dome Composite Cone
*Electroplated PPTA Dome Tweeter
*Impedance: 4 Ohms Sensitivity
*Chrome Plated Tweeter Cover
* Frequency Response: 100-20,000 Hz
* Mounting Depth: 1.61"
* 9 Oz magnet
http://www.bcae1.com/spkrmlti.htm (Reference site )
This is a series/parallel connection (below). Connecting individual woofers in a series configuration is not common in car audio. This is a lot more common in musical instrument (guitar and bass guitar) speaker cabinets.
I wanted to go with all Maxxonics products but....this deal was one i couldn't refuse.
Old 03-31-2010, 12:00 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
considering your amp is a 2 channel amp... and those speakers are 2ohms each... then a series connection (for 2 speakers) would give you two 4ohm loads.
I think that is what you are asking, not quite sure tho. It is very rare for door speakers to be 2ohms... 99% of aftermarket door speakers are 4ohms.
Old 03-31-2010, 12:23 PM   #3
_S7V7N_
_S7V7N_'s Avatar
They are 4 Ohms and i'm running it off the other side of my four channel amp. So i'm going to have four speakers. All are 4 ohms. I have two channels left on my amp. Each channel does 87 watts Rms..So i want to run Two speakers to each channel and i want a 4 Ohm load. That's why i'm wanting to do a series/parallel connection.
Old 03-31-2010, 04:28 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
you need at least 4 voice coils per amplifier channel to get a series/parallel connection.
If you have 4 coils per channel, and they are all 4ohm coils... then yeah... you can have a series/parallel connection that'll read 4ohm nominal.
Old 04-01-2010, 02:29 PM   #5
Palmer812
Drives: 2010 Meteorite Metallic LB
These guys are right you need 4 4ohm colis on a channel to be able to gat a 4 ohm load but you are using 2 channels. All 4 channel amps are stable to 2 ohm stereo on each channel so just run 2 speakers in parallel on each channel and you will be fine. You will also get more power out of the amp that way.
Palmer812 is offline   Reply With Quote
Old 04-01-2010, 03:56 PM   #6
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
the question is why? 3.5?
Mobius1 is offline   Reply With Quote
Old 04-01-2010, 04:05 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Why not ? They'll fit perfectly in the C-pillars and anywhere else i can think of to put them.
Old 04-01-2010, 04:35 PM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I also was wondering why you were going with 3.5's... If you are doing a pillar install with them, then I'd urge you to just buy 1 pair of those 3.5's, and then find yourself a 6.5"/7"/8" midbass with a low mounting depth to install in the factory door location. You'd need either a passive crossover between the 3.5 & the midbass, or you'd need another 2 channels worth from an amplifier to get the job done. The midbass would do a great job of blending the 3.5's in with a sub.
Old 04-01-2010, 05:28 PM   #9
_S7V7N_
_S7V7N_'s Avatar
I'm just using these to fill in the sound since i removed my 6x9's from the rear to get some air out from the trunk since my seats don't fold down. I have the 6.5 hifonics components in each door which sound awsome, but i think the 3.5's will fill in the rear just fine. I got two sets of these for 20 bucks, brand new, reg price is around 25 -50 bucks a set.
Old 04-01-2010, 05:36 PM   #10
Palmer812
talnlnky, has anyone here ever done a 3.5" in the pillar or dash or a 3 way component set? We are picking up Hertz-Audison and I can have a free set of speakers for my car. They have a 3 way component set with a 6 1/2 / 3 / and tweet.
Old 04-01-2010, 06:51 PM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
You know, I could probably make due with their subs & amps... and the decks are fine.... but the speakers... even if I was working with their flagship components.... I dunno... to me the components are the most important piece of equipment.
Old 04-01-2010, 06:56 PM   #12
Palmer812
I agree about the speakers. That's why I said if I do the Kenwood system I will get a set for the rears but run the Hertz-Audison's up front.
