Old 04-23-2010, 08:22 PM   #1
colinr5779
Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i
Trouble with spoiler
ive ripped my original spoiler off (yaris sr 1.8) and im left with several holes.. none of which line up with the holes drilled on my spoiler !! anyone on here had to drill holes to get an aftermarket spoiler on?
advice/tips would be helpful cheers !
colinr5779 is offline   Reply With Quote
Old 04-23-2010, 10:02 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
I've installed both factory and aftermarket spoilers on several cars. The key is to take your time and make sure you have the templates lined up perfectly. Then use a center puch to mark the locations of the holes to be drilled. Start small (the smallest bit you can use) and step your way up until you reached the desired size. I then like to de-bur the holes and apply several coats of touch-up paint to the insides of the holes. I also like to put a little silicone sealant in the holes right before I install the spoiler.
One other tip I would give, is to mask off the back of the car, including taping up seams and such. That way you don't get metal filings everywhere.
BTW, I just did an OEM spoiler install on my Yaris. Went very smoothly...no issues.
Old 04-23-2010, 11:33 PM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
The aftermarket RS-style spoiler I installed did not line-up with the oem locations I've seen on other cars. Mine came w/o a spoiler, so I had no pre-drilled holes, but I had to do some searching to figure out the best way to drill and use the hole locations on the new spoiler. If you don't want to drill into the inner wall of the liftgate, you can use an expanding "bolt" that anchors itself, kinda like a sheetrock anchor. If not, you'll have to drill through 2 layers of metal and anchor on a very angled piece of metal on the inside of the liftgate, near the hinges.
Old 04-24-2010, 12:16 AM   #4
Billiam
Originally Posted by ozmdd View Post
...you can use an expanding "bolt" that anchors itself...
If you're going to go this route...you're best bet is to use well-nuts. They will expand as the bolt is tightened without doing damage to the sheet metal around it.
Old 04-24-2010, 05:06 AM   #5
colinr5779
Colin Richardson
Cheers for the info ! i really didnt want to go drilling holes.. but it looks as if im going to have to :| wish is luck haha.. heres a pic of the spoiler. Cheers
Uploaded with ImageShack.us
Old 04-24-2010, 09:52 AM   #6
Billiam
Once you get pass the shock of drilling into the car...you'll be fine. Oh, and good luck.
Old 04-24-2010, 12:07 PM   #7
yeah, and then it becomes addictive.
Old 04-24-2010, 07:28 PM   #8
colinr5779
Colin Richardson
Its on !!!! al post pics 2moro!!
Old 04-25-2010, 12:11 AM   #9
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Holy crap, you're right!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 04-25-2010, 01:46 AM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
some one needs rehab , can i suggest you visit the Micro Image rehab centre , oh and please bring a valid credit card or cash
Old 04-25-2010, 01:00 PM   #11
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
I would just use double-sided tape. I recently bought the RBK spoiler and the instructions tell you to drill from the inside of the hatch into the spoiler. It was a pita to drill, and it seemed the drill bit did not want to go through. I just used the tape, and that bad boy isn't going anywhere(yet).
marlondog is offline   Reply With Quote
Old 04-25-2010, 04:57 PM   #12
colinr5779
Colin Richardson
Youl need to turn it with the arrows :S lol
Old 04-25-2010, 05:08 PM   #13
Billiam
I dig it.
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-20-2020 12:35 AM
TRD Vios Spoiler fitment? AdeJong 03 Cosmetic Modifications (Exterior/Interior) 12 08-24-2009 10:06 PM
RS SPOILER ... SAD aznbabiegrlx0x0 Cosmetic Modifications (Exterior/Interior) 42 09-28-2007 10:49 PM
RS Spoiler (Yes i tried to search it!!) hasher22 Cosmetic Modifications (Exterior/Interior) 2 08-24-2007 12:02 AM
Rally style spoiler in white for sale!! cheukli Items for Sale by private party 11 07-18-2007 10:02 AM
