Old 05-23-2010, 10:58 PM   #1
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
what is this?
sup y'all..
so... from this pic, what's this rod called and i'd like to change the bushings cause they're cracked... my car's 158,000miles and i'm not sure when they started cracking...
anyone changed these on their's yet?
i have tein basics installed as well.
thanx for helping in advance!
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 05-23-2010, 11:12 PM   #2
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
That is called "anti-roll bar linkage" or "Struct linkage to anti-roll bar"... Hope it help...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 05-23-2010, 11:22 PM   #3
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
https://www.toyotapartscenter.net/20...cessories.html
1) FRONT HUB
2) FRONT WHEEL BEARING
3) STRUT
4) COIL SPRING
5) STRUT BUMPER
6) SPRING INSULATOR
7) SPRING SEAT
8) STRUT MOUNT
9) KNUCKLE
10) LOWER CONTROL ARM
11) STABILIZER BAR
12) BUSHINGS
13) BRACKET
14) LINK
stabilizer bar link
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-23-2010, 11:33 PM   #4
sway bar end link
Old 05-24-2010, 12:19 AM   #5
127.0.0.1
sway bar end link
yes
this is what it is called
Old 05-24-2010, 01:08 AM   #6
barebonedvitz
sweet! thanks
Old 05-25-2010, 12:10 PM   #7
severous01
if you lower your ride you need a shorter one.
Old 05-25-2010, 12:14 PM   #8
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
SINCE WHEN..........
Old 05-25-2010, 12:45 PM   #9
^+1
I had to make a longer one for my lift kit for Crashy, but that was only because I lifted it by adding a bracket to move the strut mount 4" higher.
Old 05-25-2010, 12:55 PM   #10
127.0.0.1
only if you get shorter struts.
most lowerings do not affect
the parts the sway bar end link attaches to,
hence...NO
Old 05-25-2010, 12:57 PM   #11
127.0.0.1
^+1
u still haz a swaybar ? shouldn't crashy's plow prevent excessive body roll ? lulz
Old 05-25-2010, 02:21 PM   #12
BLAZINBLUEVITZ
ANOTHER since when.......
Old 05-28-2010, 01:55 PM   #13
severous01
hence...NO
you lowered the body of the car...so you lowered the points at which the bar is mounted to the body...the bar is supposed to be flat. move any part of it and it wont work as designed...true you didnt lower the mount on the struts, but you lowered the parts where the bushings are mounted under the car.
actually, you'd need longer ones.
if you modify one thing you gotta adjust everything involved...just like you're supposed to adjust camber if you lower...suppose you didnt. good luck keeping tires on it. you will also need a toe adjust...and probably caster will be out as well. not so much in the rear as the front.
i really dont care if you 'fix' it or not. if you like the way it handles, good. keep it that way
