Old 09-01-2011, 07:03 AM   #1
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
Exclamation putting in a new system
i have a question though, if i run my sub of an amp, will my door speakers still be able to be powered from the head unit, im a newb at this....
ttr125fan09 is offline   Reply With Quote
Old 09-01-2011, 09:23 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The short answer is yes.
Question for you:
What have you purchased so far for the system?
― Thomas Paine
Old 09-01-2011, 06:07 PM   #3
ttr125fan09
Drives: yaris
The Subwoofer
The amp for the sub
And the door speakers
its nothing fancy, just better, if you have any tips or input, please fill me in
Old 09-01-2011, 08:50 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What's the source? Stock?
― Thomas Paine
Old 09-01-2011, 09:08 PM   #5
ttr125fan09
Drives: yaris
if your talking about the headunit, its a kenwood, ill try to find out what model
Old 09-02-2011, 12:15 AM   #6
Lil Abner
Drives: 2009 3dr LB Manual
Chances are the Kenwood will have an RCA pre-out for the subwoofer. If so, then just hook your amp to that output with a set of RCAs and you'll be golden.
Old 09-02-2011, 07:37 AM   #7
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
just spend some money on the RCA cables and don't run them right beside the power wire (It makes a difference)
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 09-03-2011, 02:59 PM   #8
ttr125fan09
Drives: yaris
the hu is a kdc-138, i need an adapter for the rca cables right?
Old 09-03-2011, 03:04 PM   #9
BEEF
BEEF's Avatar
according to this picture (http://www.sonicelectronix.com/pictu...ture_id=172469) you already have RCA outputs on the back.
I don't know anything about the radio and am just going by the pics. I would just wait until you get it and go from there. get some good shielded cables and run them on the opposite side of the car. thats what we always did...back in the day. run them beside the power wire and expect some noise. it is more hassle to tear up both sides of the car but it is the details that make the difference.
Old 09-04-2011, 04:08 AM   #10
ttr125fan09
Drives: yaris
So what your saying is basically if i run my power on the passenger side, run my rca on my drivers side, so there no interference right?
Old 09-04-2011, 09:12 AM   #11
BEEF
BEEF's Avatar
basically yes.
I know guys that have ran them together without issues. I also know guys that had horrible noise and racket and couldn't figure it out and I proved that their $75 monster cable was the issue because it was butted up against the power wire. I used a $5 RCA cable once to prove this. we just unplugged his and ran it through the car (temporarily) back to his amp and voilia, all his issues went away.
one thing also is to use the same size ground as you do power wire. you don't want the RPM humm in their either.
I don't like going much below 10 gauge but that is a personal preference for me. my largest was 4 gauge and I will admit it was probably overkill but that is just how I roll.
good luck on your project.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 11:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
