![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
Had my brakes done....now handbrake is harder to pull.
So I just picked up my car from the shop. I had my front disc brakes serviced because my brakes were squealing louder than a pig seeing how bacon is prepared. But I noticed as I parked my car, the handbrake takes alot more effort to lift up. Did my mechanic tighten it for good reason? Also, what is the proper procedure for lifting the handbrake? Do you press the button and then lift, and let go? Or do you just lift, while hearing the clicking noise and let go?
Michael
Drives: 07 Silver Yaris Sedan Join Date: May 2007
he probably just tightened it for good measure like you said. as for how to work it i don't think either way will hurt anything but i always press the button in putting it on
resident senior
Sounds like they did a good job .
I use both methods of parking brake application . Everyday I just pull and listen to the clicking sound . During "killin season" , I press the button and ease the lever up and then release the button as not to alert anything to my presence . Yes when I get to the woods the lights go off and the night vision goggles go on ...........
Ok, cool, thanks for your inputs. I feel better about my car now. Hee hee! Love my Yaris!!
Michael
yep its an awsome car
Its harder because he did a proper brake job of not just doing the front brakes but making sure the rear brakes were cleaned and adjusted as a result your hand brake is properly adjusted. It was probally just very loose before for the longest time you have goten used to it. It should only go up about 3-4 clicks and then stop.
3 or 4 clicks....Got it. My hand brake was never this hard. When I bought the car, it was as loose as normal.... Glad it's good and strong now!
| Rear Drum brakes | bankrobber | DIY / Maintenance / Service | 0 | 04-17-2010 11:39 PM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
| A few questions about suspension, tires, and brakes. | supmet | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-02-2009 04:55 PM |
| Weird question about my brakes | brainless twit | General Yaris / Vitz Discussion | 8 | 01-22-2009 10:59 AM |
| Rotated tires and adjusted rear brakes today PICS | auxmike | DIY / Maintenance / Service | 11 | 11-14-2008 08:24 AM |
