![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
How to clean AFE filter?
![]() My filter looks pretty dirty to me, what do you guys think? I've had it for about 10k miles. Does it look like it needs to be cleaned? How exactly do I clean it? Is this the oiled or non-oiled version? Last edited by yarisitis; 05-10-2010 at 02:06 AM. |
First take a strong vacuum and suck out the dirt from the outside. Then you can try one of those filter cleaning products. Pep boys sells one for their generic dry filters. You spray it on the outside and let it soak for about 10 minutes. Then gently run water in from the inside pushing the dirt out. Then let it fully dry before installing. Just be careful not to use really hot water as it may cause the material to shrink a bit.
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
the instructions for the dry filter says to tap it and its pretty much cleaned then wash it for full clean.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
to be safe just use high pressure air to blow it clean, but like yaris sedan said blow it from inside out
#5 | |
Mr. 155 and climbing
Yup, Like he said...I have had my AFE since 08 and that is how I have cleaned mine. I clean mine out via air hose once a month since it is a 2 minute fix.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| AFE drop in filter | Walter | Performance Modifications | 35 | 07-27-2010 07:24 PM |
| FS: AFE drop-in filter and Stock Airbox with Cutouts | FunctionSpec | Items for Sale by private party | 16 | 06-02-2010 01:36 PM |
| Garm's AFE intake vs. TRD high flow air filter???? | computerlove87 | Performance Modifications | 28 | 07-22-2009 05:05 PM |
| FS: AFE Drop-In filter in modified airbox | mikenacarato | Items for Sale by private party | 6 | 02-09-2009 04:44 PM |
