Old 03-30-2010, 09:33 PM   #1
Billiam
Drives: '10 White Yaris 4D LB
Pic request would be a BIG help.
I was wondering if someone running this set up could link or post up some pix of their ride. I've been through all the pic threads....but still need more help deciding what it'll look like and whether I'll have any problems with rubbing.
Ideally this will be my setup:
TRD Springs
Wheels - 15x6, +39mm offset
Tires - 205/55
I don't want to run a 195/55 or a 205/50 and the wheels and springs are already ordered....so I can't change that.
Thanks in advance.
Old 03-30-2010, 09:37 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
PM Tamago
Old 03-30-2010, 09:49 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
You should be fine with that setup. I have 205/50R15 (a bit less than OEM diameter) +38 6.5" lowered. No rubbing at all. 205/55 is closer to OEM diameter, so you should still be OK. As far as looks/stance, they'll look great. You may want to consider 10mm rear wheel spacer for pure flush goodness (maybe 13mm on a 6" wheel? not sure).
Old 03-30-2010, 10:00 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I don't know if you have done this on line
But helps a lot to visualize what you are trying to accomplish.
not really pictures but looks like you are going to be OK. and like tk-421 says a 10mm spacer wouldn't hurt.
As soon as you have your car lowered just take a close look between tires and wheel wells.
CLA 250, 4MATIC
Old 03-30-2010, 10:14 PM   #5
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
15x6 +38mm with 205/50 and dropped 35mm.
I don't remember whats the drop on the TRDs but it should be close to what i have.
Never had any rubbing issue. The only thing is, 205 is a lot larger than a 6 inch wheel so they look pinched.
thepoche is offline   Reply With Quote
Old 03-31-2010, 12:40 AM   #6
derickveliz2
Very nice thepoche, If I had to do it all over again, that is how it would look like! Nice ride!
CLA 250, 4MATIC
Old 03-31-2010, 07:01 PM   #7
Billiam
Thanks for the info fellas. And yes, I played with that calculator until my fingers bled. Anyone else who wants to post up pix...please feel free. I'll keep ya posted on what I come up with in the near future.
Old 04-16-2010, 06:00 PM   #8
Billiam
Well...I went ahead and pulled the trigger on a set of ContiExtremeContacts in a 205/55 size.
Hope it all comes together as planned.
Old 04-21-2010, 08:07 PM   #9
Billiam
Wheels and tires are on. Pix will follow soon, I promise.
Final specs: 15x6, +39mm o/s, 205/55 tire.
I'm sitting on TRD springs and thus far have no rubbing issues. We'll see though.
Pic request: Canadian & EU roof rack SmellyTofu Photo-Video-Media Gallery 11 04-03-2010 03:49 AM
Pic Request: Wiper Cowl Removed Sodium Duck DIY / Maintenance / Service 2 07-06-2009 11:23 PM
PIC REQUEST - Sedans with Nitto exhaust darkmoon87 Performance Modifications 23 03-31-2009 04:18 PM
Pic Request: Scangauge mounted in pocket under single din CD player? nebulight In Car Entertainment + Electronics (audio / video / alarm) 1 04-29-2007 06:56 PM
