Old 05-16-2010, 09:34 PM   #1
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
ABS/Brake light on
Hi All,
The other day my sub's main power wire got loose and grounded...
Causing a bunch of fuses to below taking out the P/S, Aircon, Indicators, Central Locking, ABS, speedo, etc.
I managed to fix everything except for the ABS. I have tested all the fuses and they arent blowen (although I could be wrong)
Any idea what I could try to fix it?
also, can someone take a picture of the fusebox legend under the hood, mine does not have one.
mick.wheelz is offline   Reply With Quote
Old 05-19-2010, 02:37 AM   #2
Nihow
Drives: Toyota
Hi i had this problem on my 1999 celica & it turned out to be a crack on the sensor ring on the cv joint, abs light was on buy diagnostic test reveled nothing as if all was ok, so worth a check, take out the wheel sensors & look in the hole for crack in ring, i had a great mechanic to fix mine.
Nihow is offline   Reply With Quote
Old 05-19-2010, 07:18 AM   #3
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
Originally Posted by mick.wheelz View Post
Hi All,
ok since the sub wire got loose i hope u fixed that ( just joking) ok lets see u said all the fuses are fine, did u check each one by taking it out and making sure, if so disconnect your battery for about 2hours this will reset your system, this should work, wait wait, did u check if you have enough brake fuild (it could just be alittle low) let me know if u come right
www.justbabynappies.co.za
nazier is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 02:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
