Old 05-28-2010, 04:25 PM   #1
adigilani
adigilani's Avatar
Drives: Toyota Yaris Terra
Exclamation Strange problem... can anyone help...
Hi all
today i serviced my Toyota Yaris 1SZ-FE.
It has 39000 miles.
I changed spark plugs, oil, oil filter, pollen filter and air filter.
Used NGK spark plugs with 0.8mm gap.
Used 5W-30 oil
Used WIX WL7131 oil filter.
Used WIX airfilter.
Used WIX Pollen Filter
then went on to start the engine. the management light came on.
i figured that i have added bit too much oil so reduced it.
and then tried again and this time everything look normal.
however one thing, i think the engine is getting heated excessively. I saw bit of smoke from the cylinders. so switched off the engine instantly.
Took the Engine oil dip stick to check oil again and there was bit of steam or smoke again.
but oil seems to be topped up properly. there is no strange sound from the engine.
i do not know for the fact if something is wrong but i suspect there is. i didn't drive the car again.
can someone shed some light on all this...
please.
adigilani is offline   Reply With Quote
Old 05-28-2010, 09:43 PM   #2
yaris9876
Drives: yaris hatch 07 640K original m
tighten the plugs correctly and use mobile 1 or other synthetic.
yaris9876 is offline   Reply With Quote
Old 05-28-2010, 10:30 PM   #3
ddongbap
Do not listen to this synthetic nonsense.
Old 05-28-2010, 11:13 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Immediately after shutting an engine off, a bit of smoky looking blowby fume in the crankcase is normal. Smoke coming "from the cylinders" is not. I wonder if the spark plugs were properly tightened, or if they could be leaking around the threads and gaskets. The problem's most certainly not that you're not using a synthetic oil.
Old 05-28-2010, 11:27 PM   #5
yaris9876
synthetic will double the engine life... use it... forever
Old 05-28-2010, 11:37 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by adigilani View Post
Hi all
It has 39000 miles.
Used 5W-30 oil
Used WIX airfilter.
please.
Maintenance light is on because the person who did the service didnt reset it after he did your "maintance" The smoke is more than likely oil spilled oil burning off. The valve cover is designed if you spill oil while filling it there is a channel that lets the oil spill down back of the valve cover. Which is also the side of the motor where the exhaust manifold is so its hot in that area. I would not be too concerned. Just follow the maint light reset procedure and recheck the smoke in a day more than likely it will be gone.
Old 05-29-2010, 12:11 AM   #7
ddongbap
Pictures or it never happened.
Old 05-29-2010, 09:15 AM   #8
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
There exist no data on this.
TheSilkySmooth is offline   Reply With Quote
Old 05-31-2010, 04:36 PM   #9
fidgell
Drives: 2006 Yaris RS 3 door
Hi all
It has 39000 miles.
Used 5W-30 oil
Used WIX airfilter.
please.
Try NEW instead of USED....
I should charge for the help, you cant teach this stuff!
fidgell is offline   Reply With Quote
Old 06-01-2010, 09:24 AM   #10
PhillyG
Drives: 2009 Yaris
oh dear god!!! and this is why i cant help but read the forums as often as i can! ROTFLMAO
PhillyG is offline   Reply With Quote
Old 06-01-2010, 07:14 PM   #11
Yaris Hilton
Smile
HA!
Tags
1szfe, yaris
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 06:50 PM
interior lighting problem tied with headlights 40oz DIY / Maintenance / Service 7 03-28-2010 08:52 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 10:29 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
