![]() Drives: Yaris XP9 1.3 '06 Join Date: May 2016
Rear parking sensors keep beeping when nothing is behind car
Hi,
My '06 Yaris (Europe) has 4 parkingsensors in the rear bumper. When i switch to reverse gear (stick, not automatic transmission) it will give a beep, then as the car gets closer to a wall or something, the time between beeps will get shorter, untill a solid beeeeeeep when car is reaaally close to a object. However, since a few days ago, it sometimes constantly beeps (solid beep) even when the area behind the car is clear. I have cleaned the sensors with a soft rag, but they weren't dirty. Does anyone know if the car was fitted with this system from factory, or is it a aftermarket set? What steps could i take to find/resolve the culprit of this? |
Not sure if Yaris ever got them from factory, but they may have been dealer installed. Factory ones are easily diagnosed with a scanner as you can see what each sensor is reading. With aftermarket it may be a little tougher, but you may be able to unplug one at a time and see if the beeping stops. Note that it may disable the system completely with any one unplugged.
If that doesn't work, you will probably have to use a multimeter and compare the resistance of each sensor. |
I will have a look and see if i can trae the wires, it should end up in a module somewhere in the trunk i guess.
For the MK2 Yaris, the parking sensors were a genuine Toyota accessory, but they are not connected to the car's network for diagnostics.
Here is the Toyota troubleshooting guide for the system: https://www.toyota-tech.eu/aimupload...hoot_guide.pdf
Im not surprised they broke.
Such is the fate of all such things....
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
i had mine for 4 years...mines having same issue as yours...i think sh*ts getting old...😣
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| Photo-Scavenger Hunt - THE LIST | Black Yaris | Photo-Video-Media Gallery | 22 | 03-04-2009 08:35 PM |
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| Black Yaris - Photo-Scavenger Hunt | Black Yaris | Photo-Video-Media Gallery | 2 | 03-01-2009 04:13 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
