Old 06-01-2010, 11:07 AM   #1
Tracid6
Drives: 2009 3dr HB
Wheels 16x7
Hello, need to make sure,will 195/50/16 tire fit ok on 16x7 wheel ? (205 would definently look better but i just want to be sure about 195) thx for any help and info.
Tracid6 is offline   Reply With Quote
Old 06-01-2010, 12:11 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Of course it will! You're probably better off with with that tire if you have a drop.
marlondog is offline   Reply With Quote
Old 06-01-2010, 12:15 PM   #3
I run 195/50 on my 16s. You can check my garage.
Old 06-01-2010, 12:26 PM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
205/50/16 +40 fits too on trd spring. zero rub.
Old 06-01-2010, 01:24 PM   #5
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
I'm running 16x7, 195/50/16, 37mm offset, 10mm spacer, NF210,
RING-TYPE COIL SPRING STABILIZER in rear, and I still have rubbing issues in the rear
if I load the car or in front when I hit a big bump on the highway at speed. Will install a camber kit soon.
D.
CLA 250, 4MATIC
Old 06-01-2010, 02:18 PM   #6
where is it rubbing exactly? you can put blue painter's tape in the fender and wheel well liner, go drive around and you'll know.
Old 06-01-2010, 02:37 PM   #7
With my 16x7 +42 ET, 10mm spacers and a 1.5" Megan drop, I lightly rub the top of the fender wheel well arch on the right rear. With the setup Derick has, I'd imagine it would be the same location, possibly on both sides, and more severe than mine.
Old 06-01-2010, 02:57 PM   #8
derickveliz2
That's a good Idea Garm, I've been busy at work and haven't had time to install the camber kit you sent me, I'm going to load my car with a big sub-woofer box and run the exercise, but I have a general idea, in the rear hits on the metal lip of the fender at 12 o'clock, in front hits in the same area but it's plastic and has a round kind of screw (but it's not a screw) that holds the plastic fender at about 2-3 o'clock. This only happens at a specific bump on the highway if I slow down to 70mph there is no problem!
With only my self in car there is no rubbing, unless I push it really hard. But my 100 mile commute it's a pleasure to drive, specially at ramps, can't wait to put the camber kit with 1.5 degrees like you suggested.
Thanks,
CLA 250, 4MATIC
Old 06-01-2010, 06:33 PM   #9
10DG22
10DG22's Avatar
Drives: 2010 Yaris Sedan
Maybe if you rolled the lip flat that would give you extra room?
10DG22 is offline   Reply With Quote
Old 06-01-2010, 09:14 PM   #10
derickveliz2
Thumbs up
Yes!
That's next after the camber kit!
CLA 250, 4MATIC
FS: 16x7; +32 Fabulous Expand Wheels - SoCal!! MISTER_Gunnz Items for Sale by private party 10 08-15-2011 02:10 AM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
16x7 MB-Seven Wheels in Bronze w/ aluminum gold lug nuts counterfiend Items for Sale by private party 24 11-01-2009 12:11 AM
IF i do 16x7 front and 17x7 on rear wheels??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 07-07-2009 08:10 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
