![]() Drives: 2007 Toyota Yairs Join Date: Jul 2007
DIY headrest camera mount
Howdy! Stopped by to brag a little about yesterday's accomplishment -
I've wanted an in-car camera mount for my '07 hatchback for some time, but the only ones I found required some permanent modification to the car, had flimsy suction cup anchors, or were $50+. So I went to Lowes yesterday and built one: And it works like a dream. I tweaked my first design and made it smaller/lighter, and easy to store (I haven't checked yet, but it might even fit in one of the compartments next to the spare tire in the hatchback) - it's also now effortless to tighten down without any tools. Furthermore, I repurposed one of the nuts from the original design to act as a retaining nut; the camera mounting bolt no longer drops out once the camera is removed. Cost was the same, and I could actually replicate it for a few cents less in the future. If people were interested, I could easily make a kit available; it'd probably cost about $13, shipped. Also, push-on caps are readily available (I'd considered them for storing the wingnuts inside the PVC tube), but they were $1.34 each at Lowes, effectively defeating the original "budget" concept. I will, however, add a second set of holes to accommodate the narrower middle backseat headrest in the hatchback Yaris. Last edited by Echostatic; 06-09-2010 at 12:06 AM. |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
The tube you used looks like pvc electrical conduit. Am I right?
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
Half a Bubble Off Plumb
Wouldn't it work just anchored to one headrest, avoiding the need to keep both seats adjusted the same?
#4 | |
Also worth noting, the range of movement of the seat lets you pitch the mount about any way you'd need it to go, and this rig doesn't interfere with a passenger's comfort, since it's behind the posts. |
OK. I thought it looked like it was clamped to both headrests.
Sure is. Here's the equipment list, in case anyone feels like building one:
1x - 3/4" PVC electrical conduit (Lowes had 6ft pieces for 94 cents) 2x - 1/4" x 1-1/8" x 2-1/4" U bolts 1x - whatever combination of 1/4" bolt (for the threaded socket on your cam) and washer/nut to hold it in place. All holes were drilled through markings eyeballed by holding the pipe against the headrest). |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Nice! Ill be making one like ur next weekend. Good job!
Thanks! May your solution be inexpensive and effective!
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
What is the camera you are using? That short clip seemed rather steady. Does
the camera have a steady-cam feature? Is that an HD camera? |
I used two - one's the Aiptek HD cam shown there, and the other is a Sony Cybershot T20. Both are consumer-level, and both got great results!
Had a couple of ideas today that will make the mount all the fancier and raise the cost by a weensy $1 - I've switched the nuts to wingnuts (for tool-less mounting/dismounting), and I'm capping the ends so I can store the hardware inside the hollow PVC. I also swapped out the camera socket mounting bolt for a different one that I can leave in place when not in use. New pictures to follow when I get it all polished and nice looking!
(tl;dr - Didn't want to spend $50+ on a headrest cam mount, so I built a great collapsible one for $3). |
If I had stock seats, I'd be hitting you up for sure.
If your seats have posts anything like the stock ones, I can just offset the holes accordingly (or I can just send the materials for cheaper, and you can drill 'em yourself :) )
with wide enough hoops (or whatever those U-shaped pieces are called), you could go around the sides of the harness holes on racing seats... iiiinteresting!
New video added - nice drive through West Austin. Also wrote the music for it!
http://www.phreque.com/_tempor/camrig/wlh_cmtd.wmv (Video link in OP updated to this as well) |
Beast
Ive had a similiar setup to this for past years now;D, it works good for what it is, it would be way nicer to have an actual suction mount to place anywhere in the car
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
| DIY Camera Mount | ezhacker1 | DIY / Maintenance / Service | 2 | 02-06-2011 05:20 AM |
| Any interest in a universal headrest camera mount? | PlaidBear | Cosmetic Modifications (Exterior/Interior) | 26 | 11-16-2009 01:38 PM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 04:12 PM |
