Old 06-08-2010, 12:48 AM   #1
Hershey
Angry 2010 YARIS 3 door : RATTLE : air vent on the passenger side ...
has a very loud rattle . Just started during the 80+ degree temps and has remained since . You push down on it and it stops . Anyone else have this ? A fix ? You can hear it above the music too . So much for that fix .
Old 06-08-2010, 12:58 AM   #2
Nope, don't have that problem. Nothing flopping around the cabin filter box?
Old 06-08-2010, 01:09 AM   #3
Hershey
nope . It's the air vent . I'll have to remove the glove box and take a look up inside with a flashlight . Maybe some sticky back felt or 2 sided tape will diminish it .
Old 06-08-2010, 01:12 AM   #4
Got me????? Let us know if that resolves it.
Old 06-08-2010, 01:17 AM   #5
Hershey
will do .
Old 06-10-2010, 10:20 PM   #6
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
I thought I had the same problem once and I could never make it stop. Turns out that the noise was actually was coming from the rear window 3rd stoplight. I stuffed some high density foam under it and stopped the noise.
Reddog99 is offline   Reply With Quote
Old 06-11-2010, 12:46 AM   #7
Hershey
it's the air vent . Sat there listening to it while she drove . Would push down on it and stopped . I'm aware of the stop light in the hatch door . The panel itself rattles up in the upper corners where it meets the window . They hit against the metal of the hatch door . black sticky back felt helps with that .
Old 06-11-2010, 06:01 AM   #8
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
take it back to the dealer, as the car is 2010, there could be a clip that broke when they fitted into the dash, also dont tell the dealer you tried fixing it, they will fix it and bill you,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Side impact air bags... do I have them? chumpster Cosmetic Modifications (Exterior/Interior) 6 04-27-2009 08:04 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
