Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
2010 US 5 door stock exhaust, big rattle
My 10,000 mile Yaris HB has develped a loud exhaust rattle
when I am sitting still and hit reverse, the RPM's drop a bit and a loud rattle can be heard, either from the flex coupling on the exhaust or a heat shield. it sounds like a spring is loose. it is a metallic rattle that comes and goes on low rpm. doesn't happen when rpms go up. sometimes happens when I am moving from park to D and standing still. I hit the e-brake and got out of the car and it sounds like mid-body, not up near engine... Anyone else had this ? I am taking it to the dealer for an ordinary oil change and tire rotate, and was gonna ask them to check out the rattle. |
#2 | |
There was the TSB for 07-09 about the transmission control cable rattling in reverse. That same issue may be there for the 2010s as well. T-SB-0336-09 Rattle Noise from AT Control Cable in Reverse.pdf |
#3 | |
it was a bent heat-shield. odd...wonder how that happened
| 2010 YARIS 3 door : RATTLE : air vent on the passenger side ... | Hershey | DIY / Maintenance / Service | 7 | 06-11-2010 05:01 AM |
| FS: Megan Racing Exhaust n Header. | Sabretooth | Items for Sale by private party | 6 | 05-17-2009 05:04 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Exhaust rattle? | Cutie Pie #2 | DIY / Maintenance / Service | 3 | 11-14-2008 06:46 PM |
