Old 06-24-2010, 06:58 AM   #1
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
Question yaris 2009 MMT-problem in shifting gears.
hello,
i have opened this new topic although i searched for it and found only the solution for manual transmission..
I have a Multi-mode yaris since august 2009,6 gears.the gears started to squeak and crank (well-not exactly squeaking but it's sounds like 2 metals rubbing to each other for a second while trying to shift) .
this occurs mostly in 1st to 3rd gears shifts,both upshifting and downshifting,and it appears randomly ever since i bought the car.this happens also when i start the car either in automatic or manual mode, but also happen when i'm engine-breaking while using manual down shifts.
Can the lithium grease also work in MMT? Is the place to spray it identical to the picture posted here?
has anyone bumped into this phenomena in MMT?
thanks in advance,
Matan.
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 06-26-2010, 06:28 PM   #2
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
MMT...are you in the U.S. with that tranny?...hmmm,pretty neat!.
frog13 is offline   Reply With Quote
Old 06-26-2010, 06:34 PM   #3
matanfr
matanfr's Avatar
no,i'm not from the US.the MMT isn't being saled in the US.
Heretics of dune.
Old 06-26-2010, 07:29 PM   #4
frog13
Tw200--excellent!
OK...so where exactly are you?????.
Old 06-27-2010, 03:00 AM   #5
matanfr
matanfr's Avatar
i'm from the holy land.. AKA Israel
Heretics of dune.
Old 06-27-2010, 06:31 AM   #6
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Isn't your car covered by warranty anyways? I would not do anything on a MMT myself.
August 2009 - DFW Yaris Yak SaerinRhoe Southwest 55 08-19-2009 12:55 PM
May 2009 Yaris sales: Down 26.9% Thirty-Nine General Yaris / Vitz Discussion 10 06-04-2009 10:33 PM
