Old 04-30-2010, 09:50 AM   #1
leinadeb
leinadeb's Avatar
Drives: 2001 Toyota Vitz Rs
ITB swap
Hi, i'm new in here and i own a vitz rs with the 2nz engine. I am consiedering in purchaseing an itb to keep it n/a. I already have some mods in the engine such as a custom made 4-2-1 exhaust manifold, lightened flywheel, ported cylinder head and a very good custom made induction kit.
The thing is that i don't know from where to begin! Do i need to change the camshafts? What ecu or piggy bag do i need and what is the best ITB to be fitted on?
I was considering in buying the Honda CBR600 ITBS or the 4age ITBS and someone told me that with an Apexi afc neo i could work without buyin a stand alone ecu... Is it true?
Cheers
leinadeb is offline   Reply With Quote
Old 04-30-2010, 09:56 AM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
Well....There isn't a ton of info out there. It's good that you are in Malta, since the only once I've ever seen this successfully done on is in Greece. I don't speak Greek, but here is their website....www.yarisclub.gr
Keep us posted! Do you have dyno numbers with your mods? Who made your header? Thanks, and welcome!
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 04-30-2010, 10:33 AM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I would expect going IRTB on a Yaris to be disappointing under most circumstances.
You gain:
Throttle response
Top end power
Cool intake noise
You lose:
Low-mid range torque
Effortless daily driving
I've not seen it done on a Yaris, but I've seen a few Miatas with IRTBs, and unless you're just drag racing or doing it for the cool factor... it doesn't seem worth it.
Honestly, I'd skip the IRTB and just go with custom engine management so that you can tune the engine to make better use of the mods that you already have. You might get better peak HP with the IRTB setup, but I'd bet on even the stock intake to provide a fatter torque curve throughout the rev range. As the wise old-school racers say: "It's the area under the curve that counts."
Old 04-30-2010, 11:01 AM   #4
H3LlIoN
Found it...member "Kekropas" is the one running ITBs
Here is his setup. http://www.yarisworld.com/forums/sho...5&postcount=16
Toyota
Moving Forward
Old 04-30-2010, 11:06 AM   #5
Throttle bodies 38mm from CBR600, stand alone ecu and 4-2-1 custom header and the result is 145whp !!!
145 is pretty good, but remember that's on a TS.
Note: requires standalone ECU. That is a BIG project.
Sexy though!
Old 04-30-2010, 11:47 AM   #6
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Why does TS matter?
Old 04-30-2010, 12:16 PM   #7
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
ts comes with more power bigger engine
Old 04-30-2010, 12:41 PM   #8
lilredrocket
Slowy getting there
Drives: 08 Liftback
Did you read the post? It says 1NZ.... Again why does TS matter?
Old 04-30-2010, 01:10 PM   #9
^ lol
Did you read the post? It says 2NZ.... Again, TS matters.
Old 04-30-2010, 01:18 PM   #10
lilredrocket
Slowy getting there
Drives: 08 Liftback
What post are you talking about? I am talking about the link in post #4 that is about the only know user running ITB's that has posted on YarisWorld... Did YOU read? SO why does the fact that he has a TS matter? The OP of this thread has a RS not TS. Also the 2NZ is smaller...
Old 04-30-2010, 01:27 PM   #11
Ooops my bad. Getting my NZs mixed up. Anyway, the TS is a 1.8 litre is it not.
Old 04-30-2010, 01:32 PM   #12
lilredrocket
Slowy getting there
Drives: 08 Liftback
Not in the Echo I guess. If you look at the link that was posted about it says he is running the 1NZ with ITB, standalone, and custom 4-2-1 header and making 145hp.
Old 04-30-2010, 01:34 PM   #13
kou
Drives: 08 lb
The older TS is a 1.5. 145whp is good.
Old 04-30-2010, 02:22 PM   #14
1nz or 2nz its the same intake manifold setup....the only difference is the piston travel for the 0.2L difference
just buy a greddy supercharger for an xb/echo
Old 04-30-2010, 02:41 PM   #15
leinadeb
leinadeb's Avatar
The header was made here in Malta by ZISCO.. He took the exact measurments etc... Well regarding the itbs i would like to know wether kekropas did fit them on standard cams or not!!? I think that it would be a great mod since at the moment i've only got the 4-2-1 header and a good induction kit!!.. I just drag raced a yaris turbo and his time was 16.3sec and mine was 16.7sec:) Btw this is my baby vitz...
The custom made air duct...
At the Malta Drag Race Track...
Old 04-30-2010, 03:19 PM   #16
love that air duct!
Old 04-30-2010, 05:40 PM   #17
lilredrocket
Slowy getting there
Drives: 08 Liftback
Do you have any pics of your header?
Old 04-30-2010, 05:46 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
love that air duct!
+1
Great idea!
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
09 Meteorite Metallic Front Swap RacerFreakXXX Items for Sale by private party 13 07-24-2009 07:22 AM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
mid pipe swap shinlee Performance Modifications 0 02-09-2009 10:44 PM
