![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Yaris Liftback Front Sport Mesh Grille with RS badge
Sold.
Had it on my car for about a year, just took it off this afternoon and took the picture below. Price: $50 shipped. +$10 to Canada. $40 picked up. It does not fit the 2009 and newer models.
5% Tint Rear | Micro Image LED Ignition Light Kit Last edited by fmicle; 09-26-2010 at 10:55 PM. Reason: Item sold. |
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
Any damage ? Fits in a stock hatch grill ? I may want..thanks
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
What is required to install it?
Cut off the original mesh?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
I would also be interested. Any damages and installation instructions
The grille has no damage, it's just a bit dusty and I was too lazy to wash it before I took the picture. I may have seen a dead fly caught in there as well
but otherwise it's in mint condition.To install it: 1. Take off the front bumper by removing all the plastic push-pins from the upper edge and the wheel wells, then remove the bolts from underneath and then pull the sides straight away from the body at a 90 degree angle to the body. There are 3 hooks on each side, right at the edge of the front quarter panels that need to be detached by pulling away and the bumper will come off easily. 2. The OEM mesh uses similar hooks to snap into place, so you'll have to pull it off the bumper, by pushing it towards the inside (backwards if you're looking at the bumper from the front); maybe you can use a flat screwdriver to make it easier for the hooks to snap out of the grooves. 3. The sport grille comes with a few pre-drilled holes (those were already there when I got it new) so you will have to drill matching holes into the bumper, so you can attach this one. Don't worry, you're only drilling into the inside edges of the bumper, so even if you remove it and put the OEM back on, the holes won't be visible or cause any issues otherwise. 4. After you've drilled the matching holes, get some cable ties that will fit through these holes and attach the grille into place with them. The grille won't fit the contour as perfectly as the OEM, but that's normal with aftermarket parts and the grille frame is quite bendy, so you shouldn't have any trouble getting it into place, you will just have to do one hole at a time. The result, voila:
5% Tint Rear | Micro Image LED Ignition Light Kit |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
I'll take it. Pm'd
C-Lift ![]() -------------------------------------------------------------- Current Mods: MI Armrest; Full LED conversion (interior and exterior); RS spoiler; Tinted windows; Tanabe DF210 lowering springs; aftermarket door speakers; 12" RF P3 subwoofer with custom box wrapped in Neffy; seat covers; HID 8000K headlights; HID 3000K foglights; 13mm PG hub spacers; muffler delete with dual tip; eyelids; and.. A little red Domo mascot!
haven't received a reply yet
still avail PM me pls.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
| Tags |
| grille, mesh, rs badge, yaris |
| Need a front badge (09 Yaris hatch) | schleppy | Willing to Buy by private party | 3 | 07-30-2010 05:22 PM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
