Old 10-19-2008, 09:39 PM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
What are your tricks?
These are my tricks and things I do currently:
-Coast as much as possible (DFCO)
-Drive 55MPH on the highway
-Coast to stop signs and lights
-Slowly and smoothly accelerate during starts
-No A/C or heater use yet (waiting till winter)
-Windows cracked open about an inch to prevent fogging
-Monitor fuel consumption religiously
-Try to drive as close to 50MPH as possible when not on highway (within reason)
-Turn car off as soon as I come to my destination, then do everything else (put in park, put windows up, etc.)
-Let car idle only for 30 seconds to warm up, otherwise none
I can't think of anything else. Let's get this FE section bumpin'!
Old 10-19-2008, 09:45 PM   #2
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
hasnt it already been debunked that a/c does nothing to alter mpg???
Old 10-20-2008, 02:22 AM   #3
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
I recently bought a PLX Kiwi and was looking at the sensor diagnostic info that was being displayed. I played with it a little bit to see if the it did anything. Using the A/C puts more strain on the engine (doing approx. 10-15% more work), so while it may not directly affect the MPG, it is causing your engine to work less effectively and thus causing worse gas mileage.
natethegreat38 is offline   Reply With Quote
Old 10-19-2008, 09:51 PM   #4
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
In the real world, it doesn't take more than ~1.5MPG per tank.
When you think about it, it's not that much of a big expense for being sweaty all the time (At least for me, living under the equatorial heat. That, and I sweat alot.). Not for me anyway. I guess it comes down to everyone's individual priority.
DFA is offline   Reply With Quote
Old 10-19-2008, 09:56 PM   #5
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
i am bad for mpg.. i do windows down + a/c full blast when i feel necessary.. i only have windows up with passengers in the car.. now that im carpooling to work, thats more often tho...
Old 10-19-2008, 09:58 PM   #6
DFA
Compulsive Washer
DFA's Avatar
O.o
Why would you have the AC on full blast and the windows down?
Old 10-19-2008, 10:08 PM   #7
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
i like the tunes on full blast and the wind in my hair.. plus it makes me look cool.. lol jk on the last one.. i dont usually run a/c unless its over 90, heat if its under 40, both it rarely is where i am.. so unless i drive up to where garm is, i dont really need it much
Old 10-19-2008, 10:10 PM   #8
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Same as dvlnblkdrs, by myself i have the windows down and ac on, so i can listen to my music full blast and the wind. When you get red lights or such it gets hot, so u need the ac on till you start moving.
Its a Chao!!!
Old 10-19-2008, 10:12 PM   #9
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
if it makes up for it, usually only do ac on feet, not both.. air doesnt make it down there well
Old 10-19-2008, 10:16 PM   #10
Sodium Duck
╚══════════RN
Windows down + A/C.................... Is there a gas leak or something in your car? That's the dumbest thing I've ever heard of in my life. Flame the crap out of me for being rude, I deserve it. But seriously... I'm speechless.
And no, it hasn't been "debunked" that A/C doesn't affect MPG. Ask the scangaugers -- it does hurt fuel economy. What has been debunked was having your windows wide open on the highway VS A/C. Windows down is better.
This post is about what you do to help your fuel economy -- not blatantly disregard it... Let's get it back on topic.
Old 10-19-2008, 10:32 PM   #11
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
sorry, didnt mean disrespect.. i just swear i saw something on mythbusters bout that.. that is all...
Old 10-19-2008, 10:19 PM   #12
DFA
Compulsive Washer
DFA's Avatar
I either do one or the other... There are virtually no stops on the way from home to college, but there's usually REALLY heavy traffic so I'm usually idling-stopping-and-going all the time.
I use the AC when traffic sucks, windows down and full blast metal (on stock speakers ) when I can freely glide across the city streets.
Old 10-19-2008, 10:33 PM   #13
Sodium Duck
╚══════════RN
Where I am, I have a pretty clean shot to where ever I need to go. I'm on back roads where the speed limit is around 40-50mph, then I'm on the highway where I do 55mph. Probably only 10-20% of my commutes to places are in traffic. =]
Old 10-19-2008, 10:39 PM   #14
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
the car uses 7 seconds worth of gas startng. so if the light is red for longer than 7 seconds its worth shutting the car off.. if its quick its not worth it
Old 10-19-2008, 10:50 PM   #15
Sodium Duck
╚══════════RN
That's a cool fact/figure. I would shut my car off at lights, but I don't want to hold people up behind me. I like to pseudo-hypermile, I do as much as I can without interferring with other peoples commute.
Old 10-19-2008, 10:58 PM   #16
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
you can watch the other lights to see when yours is going to change. and turn the key to start the car when the light before yours turns yellow..
seems to work fine for me :)
Old 10-19-2008, 11:01 PM   #17
DFA
Compulsive Washer
DFA's Avatar
Well, back on topic. Here's what I do.
- Crack my windows down whenever I'm not stuck in heavy traffic.
- Try to use DFCO as much as possible
- Keep my tire pressure at max rated pressure.
- Pulse and glide like hell.
- Avoid rabbit starts and stops.
- Coasting. To stops, to lights, to traffic.
- Turn the car off whenever I stop to do anything. (Except stop lights, I tend to get distracted at lights, so whenever I turn it off I take like 3-4 seconds to get moving and piss everyone off).
All that and I'm getting the shitty mileage on my sig.... In a 1.3
Old 10-19-2008, 11:26 PM   #18
Sodium Duck
╚══════════RN
I forgot about that, upping the tire pressure. I figure during the winter I'll want a nice wide footprint, but come summer they're gonna be right at 44psi.
I'm also going to switch to 5W-20 Amsoil full synthetic at 5K. But I think I remember someone saying they don't make it, they only make a 0W-20 which is the same thing apparently to Amsoil -- in which case, I'll just use that.
