Old 08-16-2010, 12:36 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Need help isolating the source of my audio whining.
So its a constant whine thats there no matter what the volume setting is at. Even with the volume at zero you can hear it. It dosnt change pitch with rpm nor does it increase when things like the headlights or defroster are turned on.
I ran a seperate ground to the head unit to see if it made any difference if it did i cant tell. My only guess is it could be the power wire is running too close to the rcas. I have the cable running behind the dash and through the passanger side where the seat is so it is close to the wires in one spot. If i have to i would run it through the firewall under the drivers seat and then under the arm rest directly to the amp so its no where near the rca cables. But if im gona do that I would like to check all other possibilities first.
I do notice the higher my gain setting on the amp is the louder the whine is.
The ground for the amp is good, its a few inches away from the amp there just happend to be a 10mm bolt hole so sanded down the area and ran a bolt through.
Old 08-16-2010, 01:00 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Interesting, I'm looking for that hiss noise all the time,
I can barely hear it at zero (0) volume But this morning a very ugly noise was coming from right speakers and I moved a little bit the RCAs near the Mids and Tweeter amp (I'm in the process of connecting everything so I have wire every where) as soon as I moved them an inch or so away from the amp the noise went away.
Where are your amps?
Old 08-16-2010, 03:30 PM   #3
YarisSedan
I have a 4 channel amp under the pasanger seat. As a result the RCA cables are longer than need be. One of the cables is way too long it came with the amp install kit. So i had to bunch it up and tuck it under the glove box. The cable from the deck to the amp is run diagnally across under the carpet directly to the small opening in the carpet and then directly to the amp. Maybe if i try running it along the side of the door panel and then to the connectors on the side of the amp that will give it some distance from the amp.
Old 08-16-2010, 03:48 PM   #4
derickveliz2
Worth to try!
I wonder how others have worked out this problem if there was one?
Old 08-16-2010, 04:18 PM   #5
Here's a good troubleshooting guide for whine:
1. Verify that all levels are set properly.
2. With the system turned off, unplug the RCA inputs to the amplifier.
3. Start the vehicle and turn the system on. If the noise is gone go to step 8. If the noise is still present, it is coming from the amp or the speaker wiring. Continue.
4. Turn the system off and disconnect the speaker harness.
5. Start the engine and verify that no noise is present. In a few rare instances, I have actually heard speakers reproduce noise without being connected to an amplifier. This noise was being induced by power cables that were very close to the speaker wire. If you do have this type of noise, reroute the appropriate speaker lead and go to step 3.
6. With the speaker harness still disconnected, check to make sure there are no shorts between the speaker leads and the chassis of the vehicle. A shorted negative speaker lead will create a ground loop by establishing a second audio ground reference point. If you do have a short, trace the wire out and repair it then go to step 3.
7. With the RCA inputs and speaker harness still disconnected from the amplifier, use your VOM to measure from the shield of the RCA jacks on the amp to the chassis of the vehicle. This reading should not be a direct short (100 ohms or more is acceptable.) If this reading does indicate a direct short, you might have a defective amp and should contact the manufacturer for verification. (Note that there are a few "inexpensive" amps or boosters on the market that have their audio ground and electrical ground commoned internally. For units of this type, the information in this article will be of very little value.)
8. If you've made it here, you know that the amplifier and speaker wiring are okay.
9. Connect the accessories in front of the amp (crossovers, equalizers, etc.) one at a time and check for alternator whine. When each device is tested, there should be nothing plugged into the input of that device. In this way, we will work toward the source unit piece by piece. Be sure to turn the system power off before connecting or disconnecting any cables or accessories.
10. Repeat step 9 until all accessories have been tested.
11. If a particular accessory is causing noise, try disconnecting it's power ground wire. Go to step 9.
12. Now it's time to connect the source unit. Do that now and test for noise.
13. If noise is present, try unplugging the antenna. If the noise goes away, you will need to use an antenna isolator. This little gizmo opens the shield wire of the coax to eliminate the ground loop caused by the ground at the antenna.
14. If you still have noise, try connecting the source unit's ground wire in another location,. preferably as close to the source unit as possible.
15. Does the noise vary in amplitude when you adjust the volume control? If it does, the problem is probably power line related and not a ground loop. If this is the case, run the source unit's B+ wire directly to the positive terminal of the battery. If this doesn't do the trick, you will probably have to use a power line filter on the source unit's B+ and Ignition wires.
Old 08-16-2010, 06:38 PM   #6
YarisSedan
Wow very good flow chart. I am gonna print this out and follow it.
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 01:44 AM
PIONEER DEH-3950MP husaynkhan In Car Entertainment + Electronics (audio / video / alarm) 12 05-20-2010 02:01 AM
Source of buzzing sound.. CB900F2 DIY / Maintenance / Service 1 05-20-2009 11:19 PM
AUX Port/Zune/Cd Audio Problem therockchild In Car Entertainment + Electronics (audio / video / alarm) 4 03-15-2009 06:47 PM
JL Audio sys on my hatch?? yv1650c In Car Entertainment + Electronics (audio / video / alarm) 4 10-27-2008 01:26 AM
