StephenAdair
Drives: 2010 Yaris Sedan Join Date: Jan 2010
Yaris paint
Hello: I'm new to this forum and my 2010 Yaris is my first Toyota. I purchased it last December and I'm concerned about the paint. I've never owned a car that the paint scratched off of so easily. In the past I've occasionally had something put a small dent in a door or fender of one of my cars without scratching the paint at all. With the Yaris (it's red) the paint scratches off to the primer without being hit hard enough to even leave a dent. There are already several places where I can see the white undercoat and I have no idea what or when something came into contact with the body...unless it's from stones or something. I was wondering if anyone else has had problems with the paint coming off so easily.
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
Stephen, make sure it's just not the clear coat getting scuffed up, any pics?
Later, Al |
the yaris's paint is horrible. you're not going crazy!
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Stephen, hello and welcome to the forum.
Yes, the paint is a common issue . I have the same problem and worse, since the paint is completely scratched to the metal in some places, probably when people try to park their cars next to mine. |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I hear what you're asking, but pretty much all cars have similar paint jobs with the exception of high end luxury-which use several layers of paint to get the depth. Paint quality has changed a lot over the years primarily due to environmental regulations. Therefore, they're not as durable/thick, but they sure do shine a lot better than they did 20 years ago. Just keep it waxed and touch up chips and scratches as they show up. I get small chips from rocks in the hood and front bumper-mostly due to it's angle or flat side alowing a hard impact. I've noticed people complaining about the paint quality of the Honda fit too, but I think it's mostly due to the slope of it's hood allowing more to hit it than their last car did. Smart fourtwo cars are also seeing a lot of paint chips in the hood/front bumper area-and they are made out of flexible plastic. It's all in the slope of impact.
StephenAdair
Thanks everyone...
I think that kind of answers my question.
Other than the paint problem...so far I love everything about the car.
Drives: 2010 Yaris LB (Prev: 07 Sedan) Join Date: Mar 2009
The paint suckkkkkkks. If you look at it the wrong way it will scratch hahah
Drives: yaris sedan Join Date: Mar 2010
My paint seems to be holding up fine. A little over 50,000 miles and the car is almost 3 years old, and I only have a few tiny scratches in the hood. The bumper is riddled with chips, but the plastic is silver all the way through. I don't think 20 bucks of touch up paint every couple of years is that bad.
I blame the government for not sweeping the freeways as much as they need to, as much as I blame the EPA for weakening the paint. There pretty much isn't a safe place to pull over on most freeways I drive as there are random car parts, retread, 2x4s, rocks, and misc debris almost filling the entire shoulder. Any vehicle that is lifted without mud guards coming down to at least the axle is third on my list. |
Guess I've been lucky so far. Not a single scratch or ding anywhere on my Bayou Blue, just about 3 chips on the nose area where a rock got past my 3m film defenses.
Yes, the paint formulation has changed form what it was in past years.
For one thing, lead is no longer used in paint as it has been outlawed by most countries. Lead gave automotive paint its " toughness"? However, another problem is Toyta uses robots to paint as do most all auto maufactues these days. Robots allow a precise paint job that applies no more paint than nessary to achieve an even coat. In short, they use as little paint as practacle In years past when it was done by hand, the painter woul err on the side of caution to get a good coat of paint. As someone pointed out, if you want to get a heavy coat of pant on a car theses days be prepared to spend premium $s on a luxury model . The increased cost of the extra paint is one of the things factored into the higher prices. |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
yes same here but meguiars scratchx has worked wonders for me.. dont know what i would do without it
![]() ![]() Drives: 08' Toyota Yaris Hatchback Join Date: Mar 2009
Has anybody wet sand the orange-peel off yet?
moses |
Drives: 2007 Toyota Yaris Join Date: Apr 2010
Yaris Paint Problems
I own a 2007 Yaris hatchback in absolute red. I'm having issues with my paint as well. My front end is peeling down to the white base coat. It looks as though someone took a water balloon, filled it with paint and chucked it at my car. I only have 38,000 miles on it and Toyota won't do anything about it since their warranty is only good for 36,000 miles. I've been given the run around by Toyota corporate to go see my dealer. Well after 3 people there looked at it and said it was a defective paint job, I was asked to go back again! You would think with all the PR issues that Toyota is having that they would try and make their car owners happy. Big Fail on Toyota's part
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
You can put a clear bra on it or buy a le bra for the whole nose. Just keep the underneath of the bra clean and waxed, take it off every couple of weeks and clean the area. Otherwise invest in some touch up paint and keep on it with a good wax job.
Yes, the Yaris paint leaves much to be desired. The slightest touch leaves a mark.
I just filled 6 stone chips on the hood which were to the primer. All occurred during this past winter. That brings it up to about 12 repairs on the hood alone. Soon I'll need to have the hood sanded and repainted. Or just upgrade to carbon fibre.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Funny, just saw this thread. I was vacuuming my floor mats and I set them on the hood to make it easier to work on. When I was done the tiny amout of dirt that was on the bottom of the floor mats TOTALLY scratched up my hood. I did a turtle brazil wax job on it - since most paste wax has light clay in it to fill miro scratches. Its better but. Is there a good clay bar or wax for fixing the heavier clear coat scratches? This Clear coat scratches VERY easily, even plastic rubbing on it a tiny bit will ruin it :(
![]() ![]() ![]() Drives: 2017 VW Jetta 1.4L Manual Join Date: Feb 2009
I have no real paint issues with my Yaris, outside of four tiny (BB size) rock chips. Touch-up paint fixed the rock chips just fine.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I worrie about the long term effects of the magnesium cloride they use in the winter has on the paint.
Making a decision without following it with an action is still a fantasy. |
| Im in Yaris heaven..... (Special Edition Yaris) | YAR1S | Photo-Video-Media Gallery | 77 | 06-16-2010 10:55 PM |
| New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
| Yaris from New Zealand model - some differences to Canadian RS Yaris model | Super_BQ | General Yaris / Vitz Discussion | 0 | 07-23-2007 02:54 AM |
