![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Bypass Immobilizer?
I've been reading the forums, and haven't found a solid answer. My 2009 LB has the factory keyless with immobilizer. Yeah, it's great, but I don't want it. I have a high-end Viper system I'm going to be installing to replace the factory. Being in Michigan, the 1-mile range and remote start is handy (yes, even on my 5-spd), which needs to bypass the immobilizer. And before anyone asks, I also install a custom neutral safety switch just to be safe!
Question is, if I remove the factory alarm module, will the immobilizer/transponder also be bypassed? Or will I need to purchase a transponder bypass kit? Or can I bypass it without an add-on? My mom Camry, I took a key, wrapped it with 8 coils, then wrapped around the ignition, and it worked. Some other wires, but that's the basic idea. Any help is greatly appreciated. |
#2 | |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Which Viper alarm do you have? The new ones are made to work with manual transmissions. No special parts needed. If your car is like mine it came with 3 keys so when I do my remote start I am going to do the key in a box route because it is cheaper and I will still have 2 keys left.
Palmer812, I don't remember which Viper I have. I purchased it 6 years ago to replace my Clifford 8000. It's one of the 2-way pager ones, blue remote, all the bells and whistles. Mine is too old for the manual transmission thing, so I just have my own safety switch that I'll wire in place. I also only got 2 transponder keys with mine, so one will probably be going under the dash for a bypass. The other one will be put in my safe. Hopefully I can get it installed next week along with my other goodies.
| How to throttle body coolant bypass? | kliwonz | DIY / Maintenance / Service | 0 | 05-24-2010 01:50 PM |
| Eclipse AVN4430 Video Bypass | rexseesyou | DIY / Maintenance / Service | 3 | 04-15-2010 05:59 PM |
| Fuse bypass on Fog Lights | lablancjc | DIY / Maintenance / Service | 19 | 02-03-2010 07:38 AM |
| Video bypass? | rexseesyou | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 09-07-2009 11:45 AM |
| After-the-fact engine immobilizer? | Echostatic | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-01-2007 11:03 AM |
