![]() Drives: Yaris 2 Join Date: Jul 2014
Hi everybody,
![]() I have a 2009 Yaris with the 1NDTV turbo diesel engine (1.4L D4D 90hp). I would like to have some information about boost pressure standard values. A boost pressure vs rpm curve would be great, but even an info about the standard maximum boost pressure would be helpful. P.S : the engine has a Variable Geometry Turbocharger, so no wastegate. Thanks for your help
Bump
Only Happy When it Rains
Not sure anyone knows. PM CTScott, he might have an idea, or maybe an idea where you could acquire that info.
Colin Chapman disciple |
I have never seen a chart, but according to the service manual the max boost at 5100-5250 RPM should be 2.2 to 6.5 psi.
Thanks CTScott
![]() So that is a maximum boost up to 6.5 PSI above atmospheric pressure I suppose. I have the service manual for the petrol Yaris 2. Where can I found/download the diesel service manual? |
Correct. I will send you what I have for the diesel.
Thank you very much for the link CTScott.
Drives: 1.4 D 90 BHP MT6 Join Date: Dec 2014
I also enjoy a diese 90 bhp. I am planning some mods to achieve better cooling and performance but I only have the petrol manual. Can you send me the diesel one, please?
![]() ![]() Drives: Yaris Join Date: Apr 2009
1NDTV from 2009 boost peak 0.85bar and costant boost 0.7bar, to increase the boost you have to remap the ECU.
I remapped the Ecu and now I have boost peak 1.1bar and costant boost 0.9bar for 110hp ;) |
![]() Drives: 2006 Hatch 1.4 D4-D Join Date: Jul 2013
I have to kind of agree with Giupo, i can't remember stock boost on my 06 D4D.
But after i mounted a power box on the common rail sensor boost where about 0,9-1,1 bar. For some time I had a power box on the MAP sensor, boost where 1,4-1,5 bar (peak boost 2 bar++) stock sensor is "blind" over 2 bar. Stock ECU reduces diesel pressure if boost is 1,5 bar. I think stock turbo is good for about 140-150 hp max. I've mounted a bigger VNT turbo, bigger ic, portet top and bigger trottle valve, and aiming for 180 hp. |
![]() Drives: 2009 yaris xp90 1.4 Diesel Join Date: Jun 2020
| Tags |
| boost, d4d, diesel, pressure, turbo |
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 09:08 PM |
| Yaris d4d flashing hazards help!! | djmix | DIY / Maintenance / Service | 0 | 06-08-2014 07:18 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| yaris d4d | Kiddi J | General Yaris / Vitz Discussion | 11 | 04-21-2006 03:17 PM |
