Old 07-14-2006, 11:53 AM   #1
bladesmith6
Drives: 2007 yaris HB
scion header interchange?
Does anyone know if the any of the 4-2-1 headers available for the XA or XB will fit on our configuration? I have the lift back and was thinking their is a chance since they are the same engine after all. Please chime in if anyone has looked into this or tried to test fit any of them.
bladesmith6 is offline   Reply With Quote
Old 07-14-2006, 12:14 PM   #2
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
I'm not sure if the O2 bungs are in the same places or not, but if that is not a problem, and there is nothing in the way, it should fit- you would need to have a custom exhaust fabricated, though.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 07-14-2006, 05:06 PM   #3
HanSel
Drives: tentative yaris owner..
yea what he said
if it all fits and there is nothing in the way, they you might have to cut or extend the exhaust pipe so that it doesnt hide or stick out of the bumper..assuming the cars arent the same length.. im not sure.
HanSel is offline   Reply With Quote
Old 07-14-2006, 05:26 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Are the Scion guys really seeing worth while gains out of a different header?
Im guessing with intake, catback, etc., it that much more noticable, but what about just the header by itself?
Old 07-14-2006, 06:23 PM   #5
HanSel
probably not. youd have to get the whole setup to feel a real difference, unless your butt dyno is really good.
from a catback, youd only gain like 3 or so hp..its not that noticeable.
Old 07-15-2006, 08:28 AM   #6
Moose
Resident Redneck
Moose's Avatar
With a decent I/H/E setup, you may see 8-10 hp to the wheels- maybe. Be prepared, though, for a loss of torque on the low end.
My other rides:
Old 07-15-2006, 05:40 PM   #7
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
You will see a lose of low end torque depending on the setup you have. If you go too big on the intake pipe or the exhaust pipe diameter, then you will see a loss of torque.
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
Old 07-17-2006, 12:25 PM   #8
ChinoCharles
Drives: LB
That kind of sucks. Torque is the thing this car lacks the most. Someone put individual throttle bodies on a Yaris and post a how-to. It would be the meanest n/a economy car on earth.
Old 07-17-2006, 02:27 PM   #9
Snake
Send a message via AIM to Snake
go with 2.25" piping and you wont see any loss of anything
just get rid of the 2 cat setup and install only 1 high flow cat with no resonators, just a muffler at the end of the setup to free up some hp
you will notice a big gain to aid with the header install
Snake is offline   Reply With Quote
Old 09-17-2006, 04:30 PM   #10
dresden_k
Honda Convert
Drives: NCP91L
You want a 2.25" exhaust pipe on a car with a weak 1.5L engine?
2.25" is ideal for an engine with twice the horsepower. With a pipe that big you'll be making that stupid, ghetto "farting" noise all around town, and I imagine you'll lose power throughout most of the range. My H22A with headwork had a 2.5" exhaust and it farted from time to time. Too *little* backpressure.
My recommendation - 2" pipe at the MOST. If you get some turbo set up, 2.25" would work - even 2.5" at the extreme end of things. In the meantime, 2". I will agree that a single high flow cat is better than two OEM cats.
dresden_k is offline   Reply With Quote
Old 08-31-2006, 12:27 AM   #11
AE86Yaris
Drives: 85 AE86/blazing blue 07
this statement makes no sense
AE86Yaris is offline   Reply With Quote
Old 08-31-2006, 07:01 PM   #12
soros151
soros151's Avatar
Drives: Scion tC 06
the car may suffer with an individual throttle body on the torque part, since maybe it will take so much air that head won't b able to keep up. There is already a follow up of individual throttle bodies for the xA and the xB.
http://scionevolution.org/forum/viewtopic.php?t=7172
There u go!
Old 07-17-2006, 03:58 PM   #13
soros151
soros151's Avatar
Drives: Scion tC 06
I say about 6 to 10 hp on the Yaris.
Old 08-29-2006, 01:43 PM   #14
NichO
Drives: Toyota Yaris 1.3 2004 HB
Question
SO..........
Does anyone know if SCION xB HEADERS fit a YARIS 06??
Has anyone tried it?
I've looked the engine bay but it seems that the headers are a bit to the passenger side comparing to a YARIS 2004 2NZ-FE (from CHILE)...
At least the 2NZ-FE and 1NZ-FE 2004 uses the exact same headers that Scion xB..
but a YARIS 2006??? are compatible?
THANKS!!
Cheers from Chile
www.yarisclub.cl
NichO is offline   Reply With Quote
Old 08-29-2006, 02:22 PM   #15
riceboy
Drives: icebox
Originally Posted by NichO
SO..........
THANKS!!
Cheers from Chile
www.yarisclub.cl
The short answer: No
riceboy is offline   Reply With Quote
Old 08-29-2006, 03:44 PM   #16
NichO
that's bad news..
how do you know this?
a LONG answer would help .. im buying scion xb headers for a yaris 2006, help would be aprecciatted to know if i can close the deal
thanks
Old 08-29-2006, 02:11 PM   #17
ChinoCharles
Drives: LB
6-10 hp on a 106 hp car is an enormous gain. Keep in mind that that piping is small for a FI setup and if you planned on throwing a turbo/supercharger on later you would be doing your exhaust allllll over again to see proper gains. Something to think about before going and having an exhaust custom fabbed.
Old 08-29-2006, 04:41 PM   #18
riceboy
Drives: icebox
do you know if the DC header for the scion will fit the yaris?? i hear that its a nice piece.. and a lot less expensive than the TRD..
It will not, bolts up fine to the block but is not in proper line for the Yaris' exhaust.
Scion xA facelift? Yaris Revenge Off-topic / Other Cars / Everything else Discussions 27 12-21-2006 11:52 PM
scion xA = luxury yaris? hhcchen Off-topic / Other Cars / Everything else Discussions 25 07-22-2006 02:05 AM
Does anyone know REAL vehicle weights of :Yaris hatckback, Sedan, Scion XA, Echo,Vitz TRD_Yaris General Yaris / Vitz Discussion 4 07-15-2006 02:07 AM
