Old 09-20-2009, 02:54 AM   #1
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
Post 808_Yaris with retrofit projectors
Since brian and peterpoop did the DIY for these projectors, I'll post the pics. I'd like to thank Garm at Microimage for bringing in awesome products! The only problem I had was the alignment for the headlights-When I had the locking nut for the projector in...the headlight cutoff was off. The locking nut was removed and replaced with a rubber washer. I then eyeballed the cutoffs for the headlights by shining them at a wall. I'm guessing that I had this problem because my car is an 09 ***One tip with baking the headlights, put wood under the headlight so you won't melt the housing*** On to the pics!
Picture Update 2/1/10-Audi Style Led Lights: It was hard for me to take a clear shot of my headlight because of the leds' brightness. Enjoy
Picture Update 2/23/10-Audi Style Led Lights: Here's a clear picture of the lights.
UPDATE 7/8/10-More pics
808_Yaris Air Runner Thread:http://www.yarisworld.com/forums/sho...655#post329655
808_Yaris Air Runner Video:http://www.youtube.com/watch?v=fUkqox5d5No
808_Yaris Retrofit Projector Pictures:http://www.yarisworld.com/forums/showthread.php?t=22461
808_Yaris is offline   Reply With Quote
Old 09-20-2009, 03:01 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
looking good! nice surprise to see them at the meet today! lol
Old 09-21-2009, 03:08 AM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
oooh perfect a 09 MM, could i see some shots further away of the car? Looking good tho.
Check out my Build thread:
Old 09-21-2009, 03:45 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
More of 808_Yaris' car with projectors can been seen in this thread.
Old 09-21-2009, 01:18 PM   #5
poncesantiago1
Drives: Yaris sedan
Hey Bro, i have a yaris sedan 1.5 but i would like to know that making that implement you had problems with the horizontal leven in the retrofit?
I hope do the same for me sedan but the nivelation is my issue.
Best wishes
Santiago Ponce
poncesantiago1 is offline   Reply With Quote
Old 09-21-2009, 01:22 PM   #6
advocate
Drives: car
The retrofit looks great! I can't wait until I get a pair!
Old 09-22-2009, 12:47 AM   #7
808_Yaris
Where is Oahu?
808_Yaris's Avatar
I'll post the more pictures soon!
Old 09-22-2009, 06:48 PM   #8
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Best wishes
Santiago Ponce
horizontal level was off when i put everything on correctly...instead of using the locking washer(i think that what you call it, it's a ring with three prongs that's supposed to lock the headlights into place), i bought a rubber washer at home depot (size is inch and a half) and used that in place of the locking washer. From there, i guided the projectors so the cutoff was level, and tied everything up.
Old 10-29-2009, 08:11 PM   #9
coffiend
coffiend's Avatar
Drives: 08 Black LB
Curious if you had the same issue as Peter with the projector not fitting in the hole and having to dremel it out a bit....
I plan on doing this relatively soon
Old 10-29-2009, 09:47 PM   #10
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Yes i had the same issue as peter. I dremeled the hole out enough to fit the projectors. I'm guessing this goes for all liftbacks, sedans shouldn't be a problem. good luck with your retrofit!
Old 10-29-2009, 11:37 PM   #11
coffiend
coffiend's Avatar
Drives: 08 Black LB
Thanks for the heads up!
Your car looks really nice, man
Old 10-30-2009, 04:39 AM   #12
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
This should be on the DIY
Old 12-01-2009, 07:56 PM   #13
Dj_SloKid
Dj_SloKid's Avatar
Drives: Yaris Sedan
Send a message via AIM to Dj_SloKid Send a message via Yahoo to Dj_SloKid
can u post a pic of the cut off ??
Dj_SloKid is offline   Reply With Quote
Old 12-01-2009, 08:36 PM   #14
find Brian's thread he has pics of the cutoff, it's very nice
Old 12-01-2009, 10:03 PM   #15
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
Any sales going for this cali yaris? I'm planning to get one for my sedan very soon.
Also will this fit any other car with H4 bulb? like the Versa?
Thank you
jamal1984 is offline   Reply With Quote
Old 12-03-2009, 12:26 PM   #16
minired5stby
minired5stby's Avatar
Drives: Yaris S liftback
Nice projectors if only one day I will be brave enough. But I'm suprised you didn't paint the housing black around the headlight.
Old 12-03-2009, 02:57 PM   #17
possible future sale, but not right now. I only have one set left in stock by the way.
Yes, this should fit into any car that uses an H4 bulb. (note that some cars, like the liftback but not the sedan, need to have the hole opened a little)
Old 12-03-2009, 03:09 PM   #18
jamal1984
thanks no problem, i can only use the dremel to make it fit. I will possible buy two in the future one for me one for my dad versa.
To put on PnP HID kit without retrofit, Yes or No? mr.white_hb Cosmetic Modifications (Exterior/Interior) 3 09-20-2009 09:43 PM
Should I blackout my housings with my retrofit projectors? Or no? PETERPOOP Cosmetic Modifications (Exterior/Interior) 26 09-08-2009 04:24 AM
Fx Projector Retrofit on tca4's car drknss99 DIY / Maintenance / Service 18 09-14-2007 10:39 PM
FS TL PROJECTORS sam07yaris Items for Sale by private party 3 07-06-2007 05:18 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 07:17 PM
