![]() Drives: 2006 Yaris RS 3Dr Join Date: Sep 2010
Replacing factory fog lights?
Replacing factory 2006 Hatch Fog Lights, a they have both been smashed by rocks. I bought them off of EBay and they told me it will be a direct fit, no wiring required, just pop out the old ones and pop in the new ones.
Anyone done this? |
I did just the opposite and it worked fine. I had a set of aftermarket ones and picked up a set of real OEM ones from someone, so I swapped those in. Same connector, same mounting - No problem.
So it should really be that easy? The seller said there are no instructions as it is made for a direct fit.... Fingers crossed I guess!
The biggest pain is getting to them...
But I have one with a cracked lens that I have been meaning to replace for a while. I've even got the replacement from Garm, but since it's not leaking moisture in it (yet), I'm gonna hold off until it does. Cheers! M2
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
I'm looking into getting a pair of bulbs off ebay, too. I'm looking towards getting some cheap no names http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT, but I'm not entirely sure whether I should go with a name brand or not. I'm also not entirely sure if I'm going to get the yellow bulbs or something brighter.
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
