![]() ![]() Drives: 2009 JDM Toyota Vitz Join Date: Jul 2010
Can I Change to a 5-Lug??
Hi Everyone,
I live in Malawi and it is very difficult to get anything in the way of decent Alloys here in a size above 15"... I would like to fit a set of 17" Alloys on my Vitz, but can only source 5-Lug types here in that size... Is there a way to change to 5-lug? Would I maybe have to change my rear drums and front discs to that of maybe the New Corolla (which is a 5-lug) to then make it fit? Sorry if this offends anyone but out here we pretty much have to modify everything and anything because there are no tuning places or accessory stores......
2011 JDM Toyota Vitz RS NCP91-AHMVK Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs... |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
If you guys have the Scion XD it's probably your best source for parts, because a lot of it is the same as the Yaris. I'm not sure how much you'll need to swap though.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Contact TireRack. They'll get the correct 4x100 stuff to you. Shipping charges should be less than converting your car to another spec.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
Out in PR a lot of the Yaris vehicles are doing just that and using RAV4 rims looks cool, go for it
Theres no TireRack in Malawi, LOL its in the middle of Africa and no such thing as a Scion here...!
Big lo, any idea how they change to 5-lug?
Sure buddy I'll get the info to you ASAP I have a buddy who did it and is rocking the Rav 4 rims not my taste but a good job at that, from what I know the stock hub is very easy to take off and you need a special rachet to do so, I'll pm you with more info
Only Happy When it Rains
they make things to do that, grr I can't remember what it is called. But on some cars swapping to different lug patterns is common, maybe if you search around on the net you'll get lucky and find something.
Colin Chapman disciple |
Drives: yw calls me douche and racist. Join Date: Aug 2007
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
You would need hubs from a Toyota Ist
Seems like the Toyota Ist is a 4-Lug as well.....
The right way to do it would be to change the hubs, but the easy way to do it would be with wheel spacers that are also 4 lug to 5 lug adapters:
![]() http://shop.adapterkings.com/4-Lug-t...g-to-5-Lug.htm |
CTScott... Thanks for that!
I have been searching online as well, seems like most of these kinds of adapters are like 2 inches thick... surely that will push my wheels out like a tank! LOL will contact Adapterkings and see if i can get something to work... ;)
The thinnest ones I've seen are 1" thick. If you are buying new rims, you can compensate for the thickness in the offset of the rim.
#14 |
Might I be able to skim a bit off the rim to compensate for the thickness of the adapter...?
#15 |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
As a DIY? Probably not.. If you have any wheel manufacturers around your area you may be able to get them to mess with it. (i.e. we have Diamond Racing Wheels in Wisconsin who will modify wheels.)
#17 |
I read somewhere that adapters can be found only 8mm thick, would be great if i could find some like that - the other option i am looking at is to change the rear hubs and front rotors to those of the latest corolla as it is now a 5x100pcd........ (?!) Might that be a better option?
#18 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you can do some research on that bearing/hub combo. find a hub w 5 lug and press out your hub...i know it's a sealed bearing but it was assembled somehow. you could also buy the bearing since you're going through all the trouble and it's just another step to press in/out the old bearing.
press out the old hub, press in the new hub...no biggie. specially for someone who has to 'modify everything to fit anything'...per se'. i think that the hubs on a corolla will fit just fine. i'm sure toyota is smart enough to use the same bearing/designs especially if it works...and just change the hubs out. long story short, i used a chevy truck hub/bearing on my jeep cuz it was 30 bux cheaper. the only difference was the lug size. i pressed out the 6-lug hub and pressed in my old 5-lug hub just fine. and instead of replacing my bearings every 6 months they lasted another 18 and i sold it with them still in there. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| $86.44 for oil change? I feel screwed | behour | General Yaris / Vitz Discussion | 98 | 01-04-2010 07:10 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
