![]() Drives: Gas saver Join Date: Jul 2014
My ride + another bump stop question
I've had this car for a year now and I just recently put money on it. Here are the following mods:
Tein S Tech 14x6 Miata Wheels (10.5 lbs/+45 offset) 185/60/14 Bridgestones H&R DRS widetrack 20mm Front (25mm offset) H&R DRS widetrack 20mm Rear + 6mm spacers from O'reily total 26mm (19mm offset) The car rides very close to stock except when I hit bumps while doing 55+ mph. I cut the front bump stops but not the rear since it was not mentioned in the DIY section... Is there bump stops that needs to be cut in the rear shock? The rear is pretty harsh... Please advise. Thanks! Last edited by Yaris_Mac; 07-11-2015 at 06:15 AM. |
25mm front offset/19mm rear offset:
![]() ![]() 20+6mm rear spacers ![]() 20mm rear spacer
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
I wouldn't mess with the rear bumpstops at your ride height. Do you have aftermarket shocks? I don't run bumpstops at all, but my air bags have them built in.
Sent from my LG-V410 using Tapatalk
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
You always remove the equivalent to your drop on all bump stops. If it's dropped by 1.5" for example, cut off 1.5", it's a must do.
Nonsence! TRD makes no mention of bump stop butchering in their installation instructions. Why jeopardize a strut by removing it's safety cushion. I actually switched mine out for FatCat bump stops but honestly cannot ever recall my suspension bottoming onto them. If it has they work well because it wasn't noticeable from the drivers seat.
#6 | |
#7 | |
#8 | |
The question is if there's a bump stop in the rear shocks. It sounds like there is. l'll go ahead and cut that.
Yes their are some in the rear shock assemblies
This^
I recently installed MI lowering springs an after reading countless threads on YW and other forums I decided to leave the rears and I cut the fronts by about 1/2 an inch. W/ out the bumps your hitting metal on metal instead oof , progressive rubber dampener. For example, the sport mini actually rides on it's bumps an uses it as part of its suspension. I plan on running sport struts/shocks down the road hence the main reason I left my bumps as is. I've hit bumps at 120km/h and have yet to hit hard. It's possible I've hit the bumps but because I left them intact they absorb the shock and it never feels harsh. Keep in mind the S tech's are lower then the MI' from what I've read. But i've also had quite a bit of weight in my car and still no issues. Your jarring , likely you're bottoming out the strut and hitting metal on metal. I'd bet you wouldn't feel that with your bumps at stock length.
I just lowered mine with Tein S Tech's and the paperwork was clear about cutting the bump stops 1.4 inches. We did it in the front, nothing to cut in the back from what we saw.
TRD package as in lowering springs and shocks?
I got a great ride for a lowered econo box. But of course it's no comparison to my Audi Avant.
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| "Bouncy" Ride After DF210s? | MadMax | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 05-12-2009 10:04 AM |
| Weird question about my brakes | brainless twit | General Yaris / Vitz Discussion | 8 | 01-22-2009 10:59 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Bump Stop kits now available.... | Galavoxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 04-25-2007 12:51 AM |
