Old 10-13-2010, 01:06 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
My new online store for my computer biz and YW decals
I just opened up my new online store, trying to sell surplus computer equipment and other odds and ends (like YW decals). So if you're in need of some decals or surplussed computer equipment check it out. All profits go to paying my bills, and mods . I don't have MUCH up right now, but am slowly adding stuff all the time.
http://geekwerks.ecrater.com/
Also if anyone else is interested in setting up a online store it was free, and pretty easy to do.
Astroman is offline
Old 10-13-2010, 01:19 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
slowly but surely you will become an online sales God!
fnkngrv is offline
Old 10-13-2010, 02:05 PM   #3
jcemitte
Drives: 09 yaris sedan
AWH MAN! i needed a 96 port switch, shucks....
lol cool deal man i will check in from time to time
jcemitte is offline
Old 10-13-2010, 02:19 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
I actually have a 96-port switch, haven't posted it yet, lol.
Astroman is offline
Old 10-13-2010, 02:50 PM   #5
Malwarebytes doesn't like your site. I had to allow it to add two ip's to the ignore list for it to load...
CTScott is offline
Old 10-13-2010, 02:52 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
Weird, my stuff didn't alert me of anything... Are you using the pro version of malwarebytes? I found out about ecrater from lifehacker.com. I'm running Sophos Enterprise protection along with the free malwarebytes and Spybot and it hasn't alerted me of any issues
Astroman is offline
Old 10-13-2010, 03:01 PM   #7
Yes - I run Malwarebytes' Anti-Malware Pro. The two ip's that it didn't like were: 67.215.240.91 and 67.215.240.92.
CTScott is offline
Old 10-13-2010, 05:35 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
Huh I looked them up and they're ecraters. Odd.
Astroman is offline
Old 10-13-2010, 05:16 PM   #9
sleey0
Drives: 2008 Yaris LB
I own my own computer business so I do apologize in advance but I cant help my competition lol
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline
Old 10-13-2010, 06:47 PM   #10
.Kevin.
I ain't even mad
.Kevin.'s Avatar
How exactly do you apply these decals and do they go on windows?
thnks
.Kevin. is offline
Old 10-13-2010, 06:54 PM   #11
swidd
Drives: Yaris HB
And can I get them off easily, if time comes to sell (not that I foresee ever wanting to).
swidd is offline
Old 10-13-2010, 07:01 PM   #12
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Who has a 96-port switch just lying around? LOL!
chrisj is offline
Old 10-14-2010, 02:01 AM   #13
Astroman
Modded Moderator
Astroman's Avatar
The decals are easy to install, and can be used on glass just fine, along with relatively smooth surfaces except for unpainted concrete, unfinished wood, you get the idea. Best is to clean the area with rubbing alcohol NOT windex or other cleaners as they will leave a residue, possibly not dry fast enough, and cause the decal to fall off. You peel off the backing paper, and using the edges of the transfer tape, position the decal. When your satisfied, use a item like a body filler squeege (or a credit card/store discount card can work, as long as it has a flat edge and is flexible) and starting work from the inside out in ONE direction from center smoothing the decal, then peel back the transfer tape.
Its easy to remove the decal anytime. You can either use a razorblade on the glass, or you can just pick them off. Also heat from say a hair dryer will soften it up. Then use something like rubbing alcohol and you can clean up any leftover adhesive, but if you remove the decal properly most of the adhesive will come off on the decal.
Astroman is offline
Old 10-14-2010, 02:16 AM   #14
.Kevin.
I ain't even mad
.Kevin.'s Avatar
nice I am interested pm me with the link to the decals so when I check my PM box tmr I dont forget to buy one :)
EDIT:
If possible I'd prefer a sticker that sticks from the inside either works though.
.Kevin. is offline
Old 10-14-2010, 04:31 AM   #15
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Hi bro Astroman, do you ship internationally?
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline
Old 10-14-2010, 11:03 AM   #16
Astroman
Modded Moderator
Astroman's Avatar
I can, just shoot me a PM with what your interested in and I can get you a quote. The decals are pretty easy to ship, and usually not much either.
Astroman is offline
Old 10-14-2010, 11:07 AM   #17
Astroman
Modded Moderator
Astroman's Avatar
EDIT:
PM sent.
Astroman is offline
Old 10-18-2010, 01:45 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
Got some more networking stuff added.
Astroman is offline
