Old 06-19-2006, 04:00 PM   #1
punch
punch's Avatar
where to run amp positive cable???
ok folks, got the doors speakers in, now where to run the amp wire through the firewall?? its a 4Gauge wire, didn't notice any grommets to punch through, ideas are welcome... thanks
punch is offline   Reply With Quote
Old 06-19-2006, 06:18 PM   #2
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I have a how-to on yarisowners.com - same wire guage
mikeukrainetz is offline   Reply With Quote
Old 06-19-2006, 06:40 PM   #3
punch
punch's Avatar
will check it out, thanks, same nick? also noticed a member here posted he ran his through a grommet on the passenger side, under the carpet will check this out...
Old 06-19-2006, 06:44 PM   #4
punch
punch's Avatar
i found it thanks, maybe should be under the audio section???
Old 06-20-2006, 12:19 AM   #5
mikeukrainetz
Could be in either, there is just a whole section on how-to...
If you found it and it helps thats great.
Old 12-20-2006, 04:14 PM   #6
CAJUIN
Drives: Toyota Yaris
help me i need pics or info tell me how please
CAJUIN is offline   Reply With Quote
Old 12-20-2006, 10:35 PM   #7
bigsky2
Cousin Vitz
bigsky2's Avatar
AC Drain hose - located under front passenger carpet.
Search the forums, you'll find it.
Old 12-21-2006, 04:18 PM   #8
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
I think 4 awg it's too big.. 8awg fits just right through hose hole on pasanger side..
Yaris-TJ is offline   Reply With Quote
Old 12-21-2006, 07:50 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
4awg can be done, with a bit of cutting of the gromet area of the drain hose.
Just cut a small "pie" piece out of the gromet section of the drain house, and then you can run 4awg through the hole you cut. I caulked it afterwards with silicone to seal up any leaks.
ipod aux cable YotaYarisUSA In Car Entertainment + Electronics (audio / video / alarm) 20 01-29-2007 01:11 AM
