![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
Paint/body question
Hello Everyone,
I have a some body/paint questions that are holding me up. So I had some deep scratches and a few dings in my hood from chips. The scratches I filled in with some touch up clear coat (nail polish type applicator). That filled in the scratch and created a small mound. I tried to keep brushing over it to make sure I smoothed out the mound to streak. I then cleaned the surface and did wet sanding on that area with 2000 grit paper. I smoothed out the mound and made sure I didn’t scratch/burn the rest of the area around it. I hit it with some maguer’s rubbing compound (that says clear coat safe) and I hit it with scratch x. I see a small dull area on the hood. How do I eliminate the faint 2000 grit markings that dulled part of the clear coat? The chips that went to medal were faintly sanded, cleaned, painted with rest stopper/rust paintable primer. After it dried I hit it with the touch up paint. After that dried I hit it with the clear coat. It filled in but when I sanded the mound down with 2000 grit, I have the same issue again with a slightly dull surface that’s noticeable at certain angles. I’m thinking that maybe instead of the magiers rubbing compound. That I really need to find some cutting compound? I don’t know this part is uncharted territory. I saw something about a foam applicator, can you use cutting compound on a rag and just rub at it if you don’t have an adjustable speed buffer? |
You can but the results won't be what you are looking for. Check your area for a competent detailer. A good one will have the necessary equipment and compounds to tackle that issue quickly.
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
Try using the Meguiar's Ultra Cut compound followed by a polish. I use the Meguiar's Show Car Glaze.
http://www.cardomain.com/ride/3875996 |
hmmm. I filled in a long keyed scratch in the clear coat on the trunk top. So now I'm wondering if i should just leave it or go wet sand it and all then take it to a decent place to smooth it all out.
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 01:38 PM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 01:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 04:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 04:59 PM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 06:44 PM |
