Old 12-28-2006, 06:13 PM   #1
that one guy.
that one guy.'s Avatar
Drives: silver 07 effin yaris
mr2 rims?
i was wondering if anyone thought about putting the toyota mr2 rims on the yaris? i think it would look really good what are some of your oppinions.
yaris 3 dr liftback:
20% tint
shaved emblems
blue lit hvac
coming soon:
c one front strut-on the 30th w00t
tien s tech springs
16 in ssr comps
short ram intake
and hopefully brand new Greddy cat back exaust.
that one guy. is offline   Reply With Quote
Old 12-28-2006, 06:17 PM   #2
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Won't work!
MR2 Rims = 5 bolt
Yaris = 4 bolt
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 12-28-2006, 06:22 PM   #3
that one guy.
well thats super gay.
thanks for the info tho.
20% tint
shaved emblems
blue lit hvac
coming soon:
tien s tech springs
16 in ssr comps
short ram intake
Old 12-28-2006, 06:29 PM   #4
bigsky2
Cousin Vitz
bigsky2's Avatar
No problem.
I also considered exchanging wheels within the Toyota line - I wanted the Celica GTS wheels but they're also 5 bolt.
Old 12-28-2006, 06:33 PM   #5
that one guy.
this pic shows it having the 4 lug set up tho...
20% tint
shaved emblems
blue lit hvac
coming soon:
tien s tech springs
16 in ssr comps
short ram intake
Old 12-28-2006, 06:41 PM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
Didn't know that!
This is what I found:
MK I Toyota MR2 1986-1990 (4x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)
MK II Toyota MR2 1991-up (5x114.3mm / HPO / 12x1.5 Lug-nut / 60.06mm Bore)
So you can use MR2 wheels, but they have to be from the MK I generation.
Old 12-28-2006, 07:05 PM   #7
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Νο guys, yesterday I saw some MR2 rims and they had 4 bolts.
Old 12-28-2006, 07:12 PM   #8
bigsky2
Cousin Vitz
bigsky2's Avatar
Ok, now this is really confusing...
All of the MR2s (mark II mind you) I have seen, including my friends' is a 5-bolt pattern.
Old 12-28-2006, 07:15 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
Ok, to clear things up here.
MKI MR2 85-89: 4 bolt
MKII MR2 89-99: 5 bolt
MKIII MR2 99-06: 4 bolt
Edit: I have confirmed this information with a friend owns a MKII SW22 MR2 and he also happens to own a MKI AW11 MR2.
Old 12-28-2006, 07:15 PM   #10
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
MR2 S wheels..
well, here's a couple problems
in 2000-2002 I believe.. the MR2 had 15's
in 02-end of the line, the MR2 had 16's on the rear.
ok next problem, they're different widths front to back, as well as different offsets..
here's a pic of MR2 wheels on my Corolla. keep in mind, they do FIT but not a very good offset..
so, final words, they will fit.. try and pick up two sets of rear wheels and get 16X7's :)
i believe the 15's were 15X6 in front, 15X6.5 rear.. very very narrow
Old 12-28-2006, 07:31 PM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
MR2 S = MR Spyder right?
If so, it would be classified as MKIII - so yes it would work..
I keep thinking that people want MKII MR2 wheels on their Yarii, so I keep saying no because they're 5 bolt..
Old 12-28-2006, 09:50 PM   #12
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
Mine has mr2 spyder rims . rears are wider then the front. I got these back in Sept when I got the car.
There is a pin on the rear wheels that need to be unbolted ( on the spyder wheels)
tiksman is offline   Reply With Quote
Old 12-28-2006, 10:47 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
nice wheels, tires are waaaay undersized..
Old 12-28-2006, 11:52 PM   #14
tiksman
tiksman's Avatar
yes they are the stock mr2 tires. they were almost new when I got them. I will go with a little bigger tire when I wear these down some..
Old 12-30-2006, 04:54 PM   #15
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well, i get the feeling that the mk1 older mr2 wheels will fit cause from what i have read they are 4 on 100, which is what our wheels are...the newer ones are 5 lug.
Old 12-31-2006, 02:08 PM   #16
Katana
Katana's Avatar
It is clear now.
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 09:22 PM
Rims & Tires riceboy Items for Sale by private party 19 11-25-2006 01:22 AM
New rims - old tires littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-15-2006 07:51 PM
New Springs and Rims! Lafiro Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 09-11-2006 11:26 PM
RIMS ON THE YARIS Uglyboyed Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-26-2006 03:02 AM
