Old 01-07-2011, 07:30 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Changing Gear Oil Of the C160
I am in doubt which is the drain and the fill bolts.
I do not have the C160 manual so I need to assure I am doing this thing right
Please refer to the pictures and if you are sure only reply if I am correct or not.
Old 01-07-2011, 07:39 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
yes, drain out the bottom, fill in the top. if you can figure out how to do it the other way around, let me know ;)
Originally Posted by xnamerxx
you nailed it sir.
Old 01-07-2011, 08:10 AM   #3
Parmas
Parmas's Avatar
I know the fill is from top and drain to bottom .... I meant if these are the right bolts
Old 01-07-2011, 09:58 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Yes that's correct. On th C160 there's also a bolt of the same size on the very top you can us to pour the oil into. Just leave the one on the front open to know when it's full.
Old 01-07-2011, 06:11 PM   #5
Parmas
Parmas's Avatar
The top of the transmission is a definete no way since there is too much to unplug/unmount to access it
Old 01-17-2011, 01:28 PM   #6
yloon
Drives: AE101
Hi all,
I am C160 Gearbox owner too. The Oil replacement done by normal mechanic that 1st time seeing C160.
The top holes are thru one. meaning oil can over flow to another when over filled. and the bottom are the drain plug.
I have a question here too. All my buddies said C160 consume 2-2.5 litre of oil.
But when I drain my oil, I can manage to drain out about 1.7-1.8 litre of oil only.
second question will be, what is the correct rating of gear oil we should use, I tried toyota LSD 85w90, it cause not smoothness on gear shifting.
I wonder am I using a wrong oil or not.
I know most of ppl are using motul and torco 75w90, Is there any alternative oil that is less expensive in the market?
yloon is offline   Reply With Quote
Old 01-17-2011, 02:01 PM   #7
Bluevitz-rs
Amsoil, castrol sytec, royal purple... The list is extensive. I'm using Castrol Sytec full synthetic right now 75w90. Mine doesn't have an LSD. I'm assuming yours does as you've tried the Toyota LSD stuff. If you do, GM is suposed to have some pretty good oil for LSD equipped transmissions. Give their oil a try. And mine only took about 2L when I filled it.
Old 01-17-2011, 04:04 PM   #8
severous01
royal purple or mobile1 from autozone. it's cheap, can be found in just about any rating you want (i chose 75/90) and it's GL-5 certified. you dont even need addative if you have a locker/limited slip.
Old 01-17-2011, 08:16 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
mobil1 tore up my syncros. i don't recommend it.
you nailed it sir.
Old 01-17-2011, 11:23 PM   #10
severous01
i dont think it was the oil that destroyed your syncro's.
well, i'm not going to say not to use additives because when i do and someone doesnt put it in something will screw up. so, do what you will and i'll do what i will...and let's be happy.
with my experience with jeep, dodge, ford, chevy, chrysler, limited slip rears, transmissions requiring additives, and locked rears....i've never used additive and i've never had slippage or damage due to over-heat or chattering or any other negative return from a clutch material gear...and i use only either mobile-1 or royal purple.
so again, to re-iterate, i'm not telling you not to use it, nor am i telling you it's not required....but i dont use it.
Old 01-17-2011, 10:11 PM   #11
yloon
Drives: AE101
Are you saying all rated GL-5 gearlube can be used in LSD gearbox even they dont state any LSD word on the bottle?
Old 01-17-2011, 04:20 PM   #12
Parmas
Parmas's Avatar
Mine is about 2L aswell. I saw a difference changing oil to Torco 75W/90W when changing gears. I used the Torco LSD additive but hadn't try it hard to notice difference.
Gear oil is a good investment and if done well it could last for year on normal driving so don't get cheap on that.
Old 01-20-2011, 03:44 AM   #13
yloon
Drives: AE101
Is there anyway to find out what toyota OEM gear oil for levin bz-r 6 speed with LSD?
are they using those Redline, Amsoil, and so on too?
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
