Drives: 2007 Yaris Hatchback Join Date: Jan 2011
one brake light out
Hi
got a trafic ticket...one brake light out. I replaced the bulb but the driver side brake light is still out. (the tail lights are both working). My next step would be to check the fuses. I have located the fuse box for the lights. My question is: would it be a fuse if only one brake light is out? in other words, isn't there just one fuse for the brake light circuit, which includes both brake lights????? seems odd that just one brake light is out. If its not a fuse, any other suggetions? |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
not fuse...probably the socket. check for burn marks and bent pins/tabs. happens all the time. maybe not on toyota but it's still a likely source. you can also ohm out the wires and see if it's shorted to ground or if ground is shorted to pos.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Are you running the stock tail light assemblies and bulbs?
Cheers! M2
Check page 135 on the 'electrical wiring diagram'. Looks like both tails share the same fuse. Do your license plate lights work?
| Tags |
| brake light fuse |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Emergency brake light is on constantly | AdeJong 03 | DIY / Maintenance / Service | 9 | 10-10-2009 09:32 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
