Old 02-08-2011, 03:29 PM   #1
Misterawa
Drives: 07 Yaris LB and 03 BMW Z4
Suspension advice and pic request
Newbie to the Yaris scene here. I've owned my 07 liftback for a week and I'm loving it . I'm so ready to pull the trigger on either a Tein/Tokico (blue) set up or a TRD set up, but I could really use some advice.
Which one would you go with and would you please comment on ride quality and comfort? Also, I would like to request a pic w/15" or 16" on a wheels on a lowered suspension too.
I've done some research here on this forum, but thought starting this thread would really help me make a deciscion (soon), as this car will be my "modded" daily driver. TIA
Misterawa is offline   Reply With Quote
Old 02-08-2011, 03:58 PM   #2
kou
Drives: 08 lb
Check my garage pictures i have TRD springs and dampers with 15'' wheels and the car drives very nice.
Old 02-08-2011, 05:29 PM   #3
Misterawa
Thanks kou, your car look awesome...are those TR Motorsports wheels? I'm considering ordering a set.
BTW, how much gap is there in the wheel well and how much did it drop your vehicle. I've seen #s from 1.2-1.5 inches.
Old 02-08-2011, 05:35 PM   #4
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Get some coilovers instead. I've had the tein/tokico combo, and I loved it.The only thing I didn't like was not being able to adjust height and firmness. I ended up with Ksport coilovers, and I'm happy with being able to change it up once and awhile. It is a pita to adjust, but it's better than having to change out shocks and springs.
marlondog is offline   Reply With Quote
Old 02-08-2011, 07:26 PM   #5
Misterawa
Unfortunately, coilover are outide of my budget ...
Old 02-08-2011, 07:33 PM   #6
kou
Drives: 08 lb
I would say 1.5'' drop.
Old 02-08-2011, 08:16 PM   #7
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
I have the same question as well, I got about a 200$ budget and I cant make a decision between TEIN's, Tanabe Or TRD springs. I have a stock suspension atm. on my 2009 3door hatchback. I do not know how how Ican go since I never tried to lower the car, but the roads where are live are not perfect and occasional potholes find their way under my tires.
Trubin is offline   Reply With Quote
Old 02-09-2011, 12:31 AM   #8
SAV912
Pirate Yaaaaris
SAV912's Avatar
'09 on TRD suspension. The springs themselves on stock shocks is bouncy. The full bit is pretty firm but not unbearably so. Wheels are stock 15" pizza slicers.
Hope this helps.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 02-09-2011, 10:38 AM   #9
Klink10
Klink10's Avatar
Check my garage also. Lowered on TRD springs and struts with 16 inch RPF1's. I like the feel, so no complaints.
Old 02-09-2011, 11:54 AM   #10
Misterawa
Thanks you guys! Still very difficult decision to make .
BTW, did you have to trim down the bump stops with the TRD springs?
If you had a chance to do it all over again, would you still go with the TRD springs or would you have dropped you car lower (Tein or Tanabe DF210)? I want my Yaris to be little lower, but not if the ride quality/comfort will be a lot worse than the TRDs (which seem comfortable). Thx again and keep the pics and suggestions goin
Old 02-09-2011, 12:27 PM   #11
shouldn't have to cut bump stops with TRD springs. Tanabe instructions call for cutting them in half only. I'd imagine TEIN should be treated the same way.
Ride comfort with Tein and Tanabe springs is very good, not too stiff. DF210's are only 14% over stock (just enough to compensate for the drop).
Micro Image springs are stiffer.
For a milder drop (1" - 1.25"), Tanabe NF210 or Eibach Prokits.
Old 02-09-2011, 12:34 PM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
here's a pic of trd springs with 16", stock struts. the ride was very stock, in my opinion.
did consider micro image (AOE) springs? slightly lower drop and tighter suspension.
on 15"s (first run of AOE tigertec springs):
on 16"s (first run of AOE tigertec springs):
Old 02-09-2011, 01:01 PM   #13
i run eibach sportlines and stock shocks...ride is good due to the progressive spring rates
they also came with shorter bump stops for the front struts...
Old 02-09-2011, 01:47 PM   #14
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
I have eibach prokits and 15 inch toyota wheels with 196/60 tires,tokico hts dampners,gt spec braces,etc.
Ride can be rough as a Cobb or almost factory ....can also be a bit unstable at freeway speeds, if the shocks are not tuned well to the springs.
Car handles very well ,for what it is,i have done a few tests and overall I like it.
Tuneing a suspension correctly can be a chore. It took me 2 years to get my 70 stingray to be a excellent handling car.
IMO....I dont just go in for lower it as far as you can add super stiff springs ,bolt on as big a wheel with as low of a profile tire as you can etc...this never works out in reality unless you just like to have the "look" and cruise a strip at legal speeds.
annn is offline   Reply With Quote
Old 02-09-2011, 07:11 PM   #15
Misterawa
Looks like I'll be goin with a set of Tein DF210's and Tokico (blue) shocks and struts from Garm. I cant wait till my stock Yaris is modded .
Thanks again you guys for the pics, links to pics (garages) and all the info! Please continue to post pics of your dropped liftback on some 15 or 16s.
Old 02-09-2011, 10:30 PM   #16
SAV912
Pirate Yaaaaris
SAV912's Avatar
Just a note: The TRD springs and shocks are mated to eachother. There is no need to cut the bumpstops with both in tandem. Using just the springs will lead to a little bit of bounce in the front end. I had my springs in before the shocks but didn't cut my bumpstops because I knew I would eventually pair the two. Your mileage may vary.
-SAV
Georgia Bulldogs!
Old 02-09-2011, 10:37 PM   #17
16's lowered almost 2 inches here
File Type: jpg 38415_1443628145181_1667442286_1052647_4541594_nV2.jpg (54.6 KB, 229 views)
Old 02-09-2011, 10:50 PM   #18
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Nice looking yaris !
17 inch wheels with stock suspension Soni Wheels, Tires and Suspension Forum sponsored by The Tire Rack 41 05-23-2015 07:09 PM
