![]() Drives: 2010 Yaris Join Date: Oct 2010
Side mirrors
We just bought my son a 2010 yaris but did not get the power package is there a way to change the side mirrors w/o power to mirrors w/ power.
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue Join Date: Oct 2009
I don't know about the 2010, but I am guessing it may also have the wiring harness for power mirrors already to go. I have a 2008 LB and it had all the wires that I needed. I bought a switch off ebay from a 2003 xA, after checking with the wiring diagram and verifying that it was compatible. I plugged it into the harness. Then I bought 2 TYC power mirrors from Amazon. Removed the door panel (using previous DIY), removed mirrors (using previous DIY) added new mirrors plugged into pre-run harness checked their operation and bolted it back together. Viola, power mirrors for under $100.
In the pics below, you can see that you remove the storage box on the dash (squeeze the sides and pull it out). Then pop out the mirror switch blank from the back by squeezing on the tabs and pushing. You should be able to locate the 10pin connector almost right behind the blank. Plug in your switch, mount your mirrors on your door and plug them in and your done. Took me all of 30 minutes. |
![]() ![]() Drives: toyota Join Date: Feb 2011
any update? i have a 2010 also, is it all pre-wired?
IDK
But I know someone who might, were is CTscott?? Lol he can answer this with no problem,
I believe that they are all pre-wired. A while back someone asked if their car was pre-wired for power locks and in the process of checking for that (which they are not), we found that the wire was in place in the door for the power mirrors.
Do the TYC powered mirrors fold like the stock ones?
Cheers! M2
| Unlinking heated side mirrors / rear defrost | Alezius | DIY / Maintenance / Service | 9 | 11-03-2010 02:29 PM |
| auto folding side mirrors | shameer_k | Cosmetic Modifications (Exterior/Interior) | 9 | 04-21-2010 04:05 PM |
| The screws underneat the side view mirrors... | Sodium Duck | Cosmetic Modifications (Exterior/Interior) | 16 | 03-25-2009 09:04 AM |
| adjusting the side mirrors??? | brpnagger | General Yaris / Vitz Discussion | 4 | 07-02-2007 04:07 AM |
| side mirrors | got615 | Cosmetic Modifications (Exterior/Interior) | 0 | 05-09-2006 02:28 PM |
