![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
I was watching this oil change video for the Yaris on Youtube, he said to fill up with 4.3 quarts of motor oil in the 09?
![]() My 07 manual states 3.9 qts with oil filter and 3.6 qts without oil filter. He is over filling it see for yourselfhttp://www.youtube.com/watch?v=Fr6npb5_Me0 |
BTW he said it around 0:50
He's definitely overfilling it if he's putting in 4.3. My 09 owners manual still says 3.9.
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
It's still 3.9 for the 2010.
Thanks for the confirmation guys, I am going to change the oil with Chevron 5w30 soon :)
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Start out with 4 quarts of well shaken oil for O.C.. Dump oil from pan until it comes to a drip and then pour in 4 ounces new oil to help bring out more old oil from pan until another slow drip . Then clean the pan and drain plug w/crush washer ( use twice w/ no leaking ) . Put in plug . Leaves 28 ounces in bottle . Then remove oil filter , let drain , and thoroughly clean area . Pour in 5 ounces of the new oil into new filter leaving around 23 ounces in bottle . This takes about 3 times to pour into new TOYO oil filter to let it soak up the oil and install . Then pour in the 3 full quarts into engine and then the bottle of lesser oil until it has 4 ounces left in it . This usually brings it to the full mark . So , would say 3 quarts and 22 ounces to the FULL mark . Use leftover oil for lawnmowers , etc..
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
2007-2011 = 3.9
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I always just put an even 4 quarts in.
.1 qt= 3.2 oz. +/- 3.2 oz is not worth worrying about-nor is it accurately measured from a 1qt oil bottle. The guy putting 4.3 in isn't overfilling enough to cause problems but the correct answer is 3.9 as many have posted. |
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
I generally use an OEM filter (90915-yzzf1) that is a hair larger than the normal factory filter (90915-yzzf2). the f1 is slightly larger (it also has a check valve). I use a full 4 quarts with this slightly larger filter and it comes out right on the money.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
