Trying to take off a wheel .. help? :)
Hi all,
I have an issue where whenever I brake there's like a lil sound in the front passenger seat. Fiance thinks it's the caliper so been tryin to take off the wheel. Now we took off the hub cap and lug nuts. but is there something else in the center that needs to come off?? That's what it looks like because we can't get it off. If so, what the heck are we suppose to use? There was nothing in my tool bag but a weird funny looking thing w/ a circle at top. Thank you mucho.
Don't Milk the Cat! -Said by me during a game of Cranium.
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Kick the tire. I know, sounds strange. If the lug nuts are already off, a good kick is in order.
Put your butt against the fender of the car, facing away from the car. Bend your knee about 90-degrees so your foot is on the side of the wheel (on the tire). Pull your foot back, then kick. Rotate the wheel 90-degrees, kick again. If it doesn't come off after a couple HARD kicks, then you might have a problem. Aluminum (alloys) tend to react to the steel rotors, which gets them stuck. The steelies can also rust. Let us know if that helps. |
so there's no center piece that is holding this thing in?? Because it looks as if it's like screw on there in the center. hmm.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
hit it from the back with a rubber mallet....the heavier you can find the better. deal with this all the time with bmw's......i'd hate to have to change a bmw wheel on the side of the road, they dont wanna come off.
or do the kick trick. just watch your momentum, i've knocked a car off the jack stand doin that. |
That large center nut is on a LARGE threaded shaft, right? That nut actually holds the axle to the hub. It doesn't have anything to do with the wheel/rim.
Kick it, I had to do this just this week with a 6 year old xB that had never had the wheels off.
#7 | ||
USAF_SrA_E-4
Happened to me to and had to kick and kick until it came out
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Yep kick it,do not,I repeat do not take off hat center nut,don't even turn it,they are on to a certain spec for the bearing load.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
After the rim is off I usually will put a little greese around the hub or where the the rim makes contact. It makes it easier to get off next time.
Making a decision without following it with an action is still a fantasy. |
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I've coated my alloy wheel contact surfaces ever since being stranded on the highway with a flat and not being able to remove it to put the spare on.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Official YARIS Wheel & Tire Guide | Black Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 404 | 06-02-2026 01:19 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
