steering wheel hub adapter
sold
Free Mustache Rides
what is the cost new for these things?
$89 for the NRG
http://www.racinglab.com/nrg-short-hub-toyota.html $100 for the other http://www.evasivemotorsports.com/Me...=WB_HUB_TOYOTA
Do you have the boot for the WB hub, or just the part as shown?
#5 | |
Our new setup does not use the stock steering column, so these are no longer of any use.
![]() ![]() Drives: toyota Join Date: Feb 2011
any idea how to disable the airbag light?
No, I don't have the stock dash in our car.
#8 | |
USAF_SrA_E-4
Free Mustache Rides
^^^^hahah. i want to see this in person. its like a weee death-proof
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
are all the controls for the car on the right windshield washer / blinker controller ?
![]() Drives: Toyota Yaris 1.5 M/T '06 Join Date: Oct 2009
I don't quite get why you said it didn't have a provision to retain horn.
as for airbag i do believe a member here said something about by passing both the connector with a resistor, 5ohms IIRC. if it's just some little wiring for horns to work im interested. |
bump
Bump for new ridiculously low price.
#14 | |
To bypass the dual squib airbag you would connect two resistors across the two airbag connectors. 2.2 to 4.0 ohms are the typical values used for this purpose. As for the horn, with a hub adapter you lose the spiral cable (AKA clockspring). The spiral cable is a device that allows the horn and airbag wires to be able to be rotated back and forth without eventually snapping. Some hub adapters have their own version of a spiral cable to allow a horn switch to still remain on the rotating steering wheel. In a worst case, you could mount a switch to the dash and wire the horn to it.
killer deal [bump]
Update, found the horn wire harness for the NRG unit.
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
consider the NRG hub and horn harness sold. PM me your paypal info so I can send the money
"It hurts more when its wet" |
#18 | |
Thanks
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| Steering wheel hub adapter | spdfrk | Cosmetic Modifications (Exterior/Interior) | 7 | 02-18-2011 05:44 PM |
| Steering wheel adapter for TS | sadha | Yaris TS Talk | 4 | 07-14-2010 10:32 AM |
| WTB: OEM LB S Spoiler and Steering wheel hub adapter for aftermarket steering wheels | kustom play | Willing to Buy by private party | 1 | 02-21-2009 02:42 AM |
| steering wheel hub adapter | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 0 | 02-26-2007 12:14 AM |
