Old 07-03-2010, 12:48 PM   #1
jznomoney
Drives: Yaris Sedan
Air Conditioner Refill
How do you go about refilling the AC coolant in the car? I think I accidentally unscrewed the part and let all the coolant out for the ac. Is there a guide for this? Model is 2007 Toyota Yaris Sedan USA.
jznomoney is offline   Reply With Quote
Old 07-03-2010, 04:30 PM   #2
mimelio
Drives: NONE
http://www.etimago.com/yaris/repairm...nditioning.pdf
mimelio is offline   Reply With Quote
Old 07-03-2010, 05:07 PM   #3
jznomoney
Drives: Yaris Sedan
There is no user written manual for this? I want to buy one of the store refill kits so I don't have to pay a dealer to do this.
Old 07-03-2010, 09:16 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ Then you'd have to follow the directions of the refill kit anyway.
Old 07-04-2010, 03:54 PM   #5
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
I don't think so . . .
It would be VERY HIGHLY UNLIKELY that you released the freon from your AC system. You need to remove something with a wrench and the possibility of your getting hurt is very high... it would hiss and smoke (atomized oil) would blow out too. Are you SURE you did ? Actually sounds more like pulling our chains, or trolling to me.
Take a picture of where/what you did to remove the freon. BTW the freon is mostly a gas when released and not "AC Coolant" to equate with radiator coolant
bobolinko is offline   Reply With Quote
Old 07-05-2010, 12:43 PM   #6
jznomoney
Drives: Yaris Sedan
When It happened I loosened the wrong bolt and it sounded like compressed air coming out the the bolt shot off and a cloud air came out from under the car and it smelled like it does when the ac is running inside the car.
Old 07-05-2010, 01:28 PM   #7
RedRide
RedRide's Avatar
To be honest, if you don't really know how to do it properly, it is best left to a "professional". Many shop have "specials" on recharging AC systems so you can keep a look out for them.
If you do it yourself and you still have an unidentified leak (or some other problem) somewhere, it can quite possibly end up costing you more than it you had it professionally done to begin with.
Also, many shops have free AC sys checks and can probably tell you exactly what is wrong with it..
Old 04-21-2011, 08:03 PM   #8
athar
Drives: 1.3 cdx
i think ive fuound myself in the same situatuon today. Accidently opened that bolt thinking it was the oil drain plug.
athar is offline   Reply With Quote
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 02:22 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
