![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
axle back problems?? wont bolt down firmly
just installed a DCsport axle back exhaust and the joint were it bolts up is loose..( i can move it around and the bolts are tight.. is it suppose to have play in it like this because its gasketless??
You'll know if you can hear or feel an exhaust leak.
Never take eyes off opponent - Bruce Lee |
Okay about to go for a drive and I will get under there and see if i can feel a leak..
Okay just checked it an it is leaking a little.. what do i do? everything is tight..
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
I would go back and just unbolt and rebolt it back up, taking extra care that it's aligned right before you do the rebolting
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Do have the donut gasket in there Yarisaur? There should be a round polymer gasket that fits in the joint and gets sandwiched between the flanges under spring tension when the bolts are tight.
R2 |
| Back hurt? | yarswiss | Off-topic / Other Cars / Everything else Discussions | 10 | 11-14-2008 04:39 PM |
| Rear wiper: EZ mod so it pulls back all the way | joelitton | Cosmetic Modifications (Exterior/Interior) | 10 | 10-22-2008 10:30 AM |
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
| FS: Tanabe Concept G axle back exhaust | yrsdrgn | Items for Sale by private party | 9 | 08-20-2007 04:33 AM |
| Why are there only axle back exhaust??? | hatchbackkid82 | Performance Modifications | 11 | 04-30-2007 05:54 PM |
