![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
PO420.....so now what?
reading different things. but happy to say at least i have narrowed down problem of my previous posts on here.
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
#3 | ||
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
I would say itīs probably the oxygensensor when it says bank 1. Regards Steven. |
What?
Now you Google the code and see what it means.
it can mean a lot of things indeed, but mostly that your catalytic converter is not working properly. Have you done any kinds of mods to your car?
You best bet is to take it to the dealer to check... Or you can just clear the code and hope it does not show up again..
#8 | |
basic and simple yaris here |
and now re-reading your previous thread about putting diesel in the car, it's quite likely that the code is just a temporary one as the sensors didn't like the way the diesel fumes interacted with them. But, there's also a possibility that your catalytic converters are damaged, so taking it to the dealer is still the best bet.
#10 | |
#11 | |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I'm sorry, I really don't think there's anything anyone here can do to help... If you don't wanna go see the dealer again (understandable), reset the code and cross your fingers it does not show up again...
well its not a matter of not wanting to go to dealership. i am curisous about this almost 1000 dollar estimate mt grandma got through toyota. from what i read it looks like there is a warranty for catalytic converter up to 80,000 miles. probably read wrong though.
something wrong with the catalytic converter, i don't see how it can be more detailed than that
![]() If there is a warranty on it, and if they don't revoke it due to the diesel incident, then do it!
#15 | |
thanks for your replys by the way! much appreciated
the code p0420 from what i have looked up seems to be a common one and one with one too many possibilities. but of course. warranty = $0 at least the last time i checked. also correct me if im wrong but toyota did say wrong plugs are in, well not the brand they want are in. so that would hopefully make this a warrantable fix. no need to bring up deisel being put in over a month ago and what not. Stored: P0420 Catalyst System Efficiency Below Threshold (Bank 1) Pending: P0420 Catalyst System Efficiency Below Threshold (Bank 1) MIL ON MisFire Monitor Complete Fuel System Monitor Complete Comprehensive Component Monitor Complete Catalyst Monitor Complete Heated Catalyst Monitor Not Supported Evaporative System Monitor Complete Secondary Air System Monitor Not Supported A/C System Refrigerant Monitor Not Supported Oxygen Sensor Monitor Complete Oxygen Sensor Heater Monitor Complete EGR System Monitor Not Supported DTC for which Freeze Frame was Stored P0420 Fuel System 1 Status Closed Loop Fuel System 2 Status Not Supported Calculated LOAD Value 77.25 % Engine Coolant Temp 181.40 °F Short Term Fuel Trim - Bank 1 5.47 % Long Term Fuel Trim - Bank 1 -0.78 % Engine RPM 2339 rpm Vehicle Speed Sensor 54.68 mph Ignition Timing Advance #1 Cylinder 25.00 ° Intake Air Temperature 69.80 °F Air Flow Rate Mass Air Flow Sensor 2.57 lb/min Absolute Throttle Position 28.24 % Time Since Engine Start 1071 sec Bank 1 - Sensor 1 Equivalence Ratio 1.06 Bank 1 - Sensor 1 O2S Voltage 3.44 V Commanded Evaporative Purge 100.00 % # Warm-ups since DTC Cleared 3 Distance since DTC Cleared 27.34 mi Barometric Pressure 28.94 inHg Bank 1 - Sensor 1 Equivalence Ratio 1.06 Bank 1 - Sensor 1 O2S Current 0.09 mA Catalyst Temperature Bank 1 - Sensor 1 1274.90 °F Catalyst Temperature Bank 1 - Sensor 2 1274.90 °F Control Module Voltage 13.85 V Absolute Load Value 56.08 % Commanded Equivalence Ratio 0.97 Relative Throttle Position 10.98 % Absolute Throttle Position B 62.75 % Accelerator Pedal Position D 25.10 % Accelerator Pedal Position E 41.18 % Commanded Throttle Actuator 28.24 % Time since DTC Cleared 0 hr 53 min |
Here's as detailed as you can get:
P0420 Catalyst System Efficiency Below Threshold (Bank 1) Causes: - Front exhaust pipe (with Three-Way Catalytic Converter) - Gas leakage from exhaust system - A/F sensor (sensor 1) - HO2 sensor (sensor 2) If it was a timing error or plug not tight, you'd have a different code, that's the whole reason for being of these diagnostic codes, to help you pinpoint the problem, not maybe something else ![]() Thanks for posting the stored freeze frame value, quite interesting! Only thing that I think is out of order: Bank 1 - Sensor 1 O2S Voltage 3.44 V Looking at the repair manuals the normal range for this sensor should be usually less than 1V? So yes, in this case, it seems to narrow the problem down to the O2 sensor being defective. But don't take my word for it, I am not a qualified mechanic, just a geek who likes to look up and understand technical information
#17 | |
keep in mind that i have not read manual on this code reader so i only had about 2 minutes earlier yesterday to plug in and see if anything would happen. im wondering when i try it out today. is there more i can do while using the reader to get more info. or is it really as simple as plug in. wait, unplug and view on pc? im not even sure how i did that freeze frame thing. time to look into that. thanks geek
well the way I see it, either something wrong with the cat is causing the (perfectly fine) sensor to read out of range, or the sensor itself is faulty. Without a Toyota technician's actual computer tester unit ($2000+ on eBay), there's no way to know without physical inspection.
