Old 05-29-2011, 09:04 PM   #1
sg11
Drives: 2010 Liftback
pinging
So for a while now I've noticed that my engine seems to what I believe to be pinging and since it has gotten hotter out it seems to have become more pronounced as pinging does in warmer weather. I've been reading a lot on here and in general about the subject. From the info I have gathered it seems some light pinging is normal and that it is common with the Yaris and even though the manual suggests an 87 or HIGHER octane fuel the general consensus seems to be that putting in anything more than 87 is a waste of money. From what I have read the Yaris with its 10.5:1 compression ratio engine is considered to be high compression. My question is if a car such as the newer Honda Civic Si which has a ever so slightly higher compression ratio of 11.0:1 requires premium fuel then why does the Yaris only require 87?
sg11 is offline   Reply With Quote
Old 05-30-2011, 12:27 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
because the computer system has been adjusted for the 87 octane. But if you experience pinging on a regular basis I think you really need to find a better quality gas. I haven't ever experienced it and i only run 87.
If you want to try a higher octane, that is your choice, but you should keep track of everything while you do to see if you really gain anything for it. A Scanguage would be a great tool to help keep track of everything.
Colin Chapman disciple
Old 05-31-2011, 06:28 PM   #3
sg11
Hmmm. I wonder why Honda didn't adjust the computer on the Si for 87 octane?
Old 06-01-2011, 01:16 AM   #4
why?
why?'s Avatar
Drives: Yaris LB
Because they want the Si to have more power. Compression Ratio is only one small puzzle piece to what goes into an engine. With today's modern technology engines can both be monitored much more closely, and controlled much more easily.
A real way to know how reliable these cars is to go into the forced induction section and find out how many of those peep's have lowered their compression ratio.
That was something that used to be an absolutely must do.
Old 06-01-2011, 05:36 AM   #5
sg11
Hmmm. I thought it was because it HAD to run on premium due to the higher compression and that the more you compress the air and gas the more likely it is to pre- ignite thus requiring a fuel with a higher ignition point?
And as far as reliability and forced induction, did you mean to say they haven't lowered their compression ratio?
Old 05-30-2011, 01:30 AM   #6
krolos
Drives: 2008 yaris sedan
45,000 miles and I have not had any pinging at all, I run 87 chevron or shell
krolos is offline   Reply With Quote
Old 05-30-2011, 04:37 AM   #7
Blue Y job
Blue Y job's Avatar
Drives: 2007 Blue Yaris Hatch
Mine doesn't ping at all, even if sometimes I forget to downshift to first and let out the clutch with hardly any revs. But If you have a gentle throttle foot and buy crappy gas, you may have more deposits inside your combustion chambers than I do. I would stick with regular, but buy big name gas only, and go out there one day and rev the hell out of it. If that don't work you have other problems.
Blue Y job is offline   Reply With Quote
Old 05-30-2011, 09:09 AM   #8
toast
Drives: 2007 LB
sg11, it really should not be pinging. when are you hearing this? is it just at high speed crusing? or when accelerating? or idle?
as mentioned i would get some brand name gas, a good fuel injector cleaner and add it to the tank and drive it hard to try to clean out any dirt/carbon. if that doesn't do it, you should have it looked at. not good to run lean like that for too long.
toast is offline   Reply With Quote
Old 05-30-2011, 09:56 PM   #9
sg11
I hear it mostly during light throttle conditions when driving around at lower rpms or going up a hill. I always use quality gas (shell, sunoco, exxon).
Old 05-30-2011, 09:28 AM   #10
Are you actually experiencing pinging, or is it valve tapping? These cars all exhibit some degree of valve tapping. The engines are never truly silent.
Old 05-30-2011, 10:01 PM   #11
sg11
What do you mean by valve tapping? I'm not noticing any strange noises at idle.
Old 07-08-2011, 06:05 PM   #12
brg88tx
Drives: 07 Yaris Sedan, Auto
when i first start driving mine there is what i would describe a a light rattling sound. is this valve tapping?
brg88tx is offline   Reply With Quote
Old 05-30-2011, 09:50 PM   #13
sg11
For those of you who are running on 87 with no pinging, is there ethanol blended in?
Old 05-30-2011, 09:51 PM   #14
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Virtually all pump gas contains ethanol
The Spectacle is offline   Reply With Quote
Old 05-31-2011, 07:43 PM   #15
Nanook
Drives: 2011 3dr hatch
Different states have different laws regarding the use and labeling of ethanol mix with gas at the pump.
Nanook is offline   Reply With Quote
Old 05-31-2011, 03:37 AM   #16
Blue Y job
Blue Y job's Avatar
You have a 2010 hatchback, so you can't have that many miles yet. You buy quality gas. It's a Toyota and it's under warranty. Don't worry about the little sounds, it's a machine. Turn up the stereo and roll down the windows and enjoy yourself!
Old 06-01-2011, 12:03 PM   #17
sg11
I hear ya. I trust Toyota and know they make quality products. I just wanna know why its doing what its doing.
Old 06-01-2011, 11:20 AM   #18
detroiter
detroiter's Avatar
Maybe your hearing the timing chain? It's pretty noisy on these Toyota engines.
Pinging noise coming from the front right hachi-roku_fan DIY / Maintenance / Service 3 01-24-2011 05:41 PM
Knocking / Pinging TDaniel DIY / Maintenance / Service 11 04-08-2010 07:12 PM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 06:50 AM
