![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
Tom's Fuel Map Controller + TRD Racing Spark Plug
![]() Got it from Japan
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
Slowy getting there
Sweetness!!!!!
What kind of car is that?
info? :)
Some say, this product even not in the list of Tom's Japan website, so I can't find any info in the internet, only this
• Clips onto air flow sensor easily and can extend into Front panel • No cutting of any wires • ECU untouched • Control air/fuel ratio • 5 settings from effective fuel savings to more power • At top setting power increase 20-25%, Driver has control • Control hub compact, can be placed anywhere • Applicable to all Toyota models manufactured from 2005 to 2009
Slowy getting there
So how can we get these?
About the Fuel Map Controller....I really don't know except from Japan.....
I'm not sure if there's any TRD Racing Spark Plug in US available? I only can find TRD "Sport" spark plug in ebay for $30 per one.
1NZ-FE
but how did you bought it? which website?
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
I bought it directly from Japan....I just have a short trip to Japan 2 weeks ago.....
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… Last edited by AlainMikli; 09-21-2009 at 04:10 AM. |
pink wheels are cool
theres toms dealers all over
i use to use one in toronto when i would order stuff in im sure if your in a big city you could find one |
How much does it cost, and where is the performance data?
★weeaboo★
After a bit of driving, wouldn't the O2 sensor tell the ECU to fix the mixture after you adjusted it manually?
#12 | |
I asked the passenger on my car what's different between this morning( I drive the same passenger to lunch this morning) and now, he said he can really feel the car has more power, and ask me what did I done ![]() Can't wait to install the TRD spark plug with this controller
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… Last edited by AlainMikli; 09-21-2009 at 04:33 AM. |
I dont know how it works....but you can only adjust the setting before you start the car, if not, the computer will mess up everything....that's what the sales told me....
#14 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I don't understand how you can get better power with this controller and especially the plugs
Lets get straight to the plugs, these are almost identical (2 step colder) to my NGK Iridium IK22. I can assure you there is more loss than gains running N/A with these plugs as the combination of spark do not match with the air & fuel mixture. The controller (in my opinion) is useless unless it is combined with other performance mods like especially a supercharger or turbo. In the case of N/A and few mods or no mods at all, the engine can only loose power if you enrich the mixture or else if you lean it you tend to get a slight power increase putting your engine at risk! Quote:
"IF THERE ARE POSSIBLE GAINS USING THIS CONTROLLER THIS MUST BE PAST THE AFR ADJUSTMENT RANGE ON THE STOCK ECU AND SO PROBABLY PAST 2500RPM" I think this package is designed to be used on those TRD Turbo 1.5L engines and that would really make sense as turbo needs colder plugs and richer mixture which is equal to "You can increase more boost Now" .... of course if the internals withstand it |
#15 |
the retail on the box is 18900yen, and I can't find any performance data on the website......
may be you can contact Tom's US to see if they can give you any data
#16 |
^ that seems likely, but who knows - the Blitz fuel controller works with the supercharger
#17 |
★weeaboo★
This is true, but after reading a few translations of the product description from a few Japanese websites, it states that the ECU remains untouched and the only wires to connect are spliced into the MAF. I'm sure the Blitz controller does a bit more than just alter the MAF signal like this unit apparently only does.
Edit: Heh, now I see the MAF splice connector sitting atop the box. Looks well designed! |
#18 |
put it on the dyno! lol. before and then with +5!!!!!!!!
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | Today 12:44 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| Blitz owners: fuel controller question | s3r3nity | Forced Induction Forum | 28 | 05-30-2009 10:19 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 03:35 PM |
| Another S/C'd member worried about his AFR | LtNoogie | Forced Induction Forum | 181 | 04-18-2009 01:19 AM |
