Old 07-03-2011, 05:06 AM   #1
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up Bumper Cover Push type Clip or retainer P/N 90467-07071-22 alternative
YarisWorld,
Could you please post your Bumper Cover Push type Clip or retainer P/N 90467-07071-22 alternative?
Bumper Cover Push-Type Retainer
Black Nylon
Head Diameter: 11mm
Stem Length: 14mm
Fits Into 7mm Hole
Replaces Toyota: 90467-07071-22 Yaris 2009 - On
borrowed from kw531 post
We have used the Hyundai/Kia bumper retainer/Clip as it has far more better grip than toyota and it has a Philips head:
T = 18 мм.
F = 8 мм.
H = 15 мм.
D = 11 мм.
If you replace yours with a Metal one, could you please share the solution? TIA
ricepower is offline   Reply With Quote
Old 07-14-2011, 12:10 AM   #2
Z00KA
Z00KA's Avatar
Drives: 2007 Manual Bayou Blue LB
I just replaced mine today after doing the headlamp replacment...low beam wasn't working on the driver's side.
I went with a replacement that had a larger in diameter "washer". 3 of the original 5 were missing. Got mine from NAPA with a part number of 6651316.
Z00KA is offline   Reply With Quote
Old 07-03-2011, 05:17 AM   #3
rufnnek
rufnnek's Avatar
Drives: oliveMist
Originally Posted by kiel12 View Post
pre meron ka pabang natira nito??
nagdala si ruel nong friday, di ko alam kung sino sino yong mga nakakuha.
rufnnek is offline   Reply With Quote
Old 07-03-2011, 05:36 AM   #4
ricepower
ricepower's Avatar
Thumbs up
@kiel12 and @rufnnek
Pls reply in English for this thread. Thanks in advance.
--ricepower
Tags
bumper clip, bumper retainer, push on clip
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
