Old 06-03-2011, 02:57 PM   #1
RevinKevin
Drives: Yaris2010
Yaris-differences in suspension
I've got a question that the guys at my local dealership can't answer. I've had two Yaris Hatchbacks, an '07 and now a '10. My '07 had very tight rear suspension with hardly any body-roll while cornering. Now, my '10 has very squishy rear suspension, and the rear of the car actually sits lower than the front. So my question to them, and to you is, what has changed between '07 and '10. I want this Yaris to handle like my first one, so I'm gonna fix what's been changed. Thanks for your response in advance.
RevinKevin is offline   Reply With Quote
Old 06-03-2011, 03:15 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
As far as I know nothing has been changed in the suspension. It might just be your specific car might have been sitting on it's rear wheels for a long time on a slope perhaps in transport. Regardless, better cornering is nothing a rear sway bar can't fix!
Old 06-03-2011, 03:18 PM   #3
detroiter
detroiter's Avatar
I believe someone on here said that the holes where you can bolt the rear suspension arms into, they don't have threads on the newest Yarii's. That's about all I know is different in suspension terms.
Old 06-03-2011, 07:42 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
did you buy the '10 new or used?
Colin Chapman disciple
Old 06-03-2011, 08:05 PM   #5
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
the question is what did you have on your '07 ?
OTA'sTOY is offline   Reply With Quote
Old 06-03-2011, 11:02 PM   #6
RevinKevin
Drives: Yaris2010
I bought the '07 and '10 both new, and did nothing to either. They were both stock. I believe they both had sway bars listed as being on the cars but my new one is way too squishy for that to be true.
Old 06-04-2011, 01:23 AM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Well the cars technically have a front sway bar already
Old 06-04-2011, 07:50 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i got a 2010.. they do not come with rear sway bars from the factory.
Old 06-05-2011, 06:28 PM   #9
why?
why?'s Avatar
Drives: Yaris LB
I'd have someone go over the rear suspension then. A dealer if it is under warranty because something could be broken back there. There is no reason for the handling to not be identical if everything is ok.
Old 06-07-2011, 12:27 AM   #10
SAV912
Pirate Yaaaaris
SAV912's Avatar
If the rear is sitting lower than the front, then there is something pretty wrong there. Blown or seriously worn shocks? Bad springs?
I can't think of any Yaris HB I've seen that sits lower in the back on the stock suspension. Mine didn't do that with 500 lbs of potting soil. It was at best, level. Man that back was planted though!! [/awful pun]
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
Scion xd suspension on a yaris sasquatch Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-26-2010 05:06 PM
Scion xA and Yaris Suspension? 88ShelbyZ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-19-2007 09:16 PM
