07-22-2011, 01:18 AM | #1 |
Drives: 2006 Yaris HB 5DR Join Date: Oct 2008
A/C Blower Dismantling?
Good day sirs!
I have noise problem in A/C blower. I checked if some debris got sucked in and found nothing so I decided to pull down the blower out of its nest. Blower out, i rotated it manually and the sound looks like coming from the motor and it sounds same as if some materials are trapped between motor and fan axial blade. Now my problem, anybody knows how to remove the blade so I can get a better look on the motor? here are some pics for reference: thanks in advance! |
07-22-2011, 05:02 PM | #2 |
toyota
hard to see from the photo but if it was screws or clips then it can be disassemble.. ..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
07-22-2011, 05:48 PM | #3 |
DAT'S RIGHT I GOTz 2
best thing to do is replace it toyota had a TSB for this but was only 3yr36k coverage
07-23-2011, 02:40 AM | #4 |
@ OTA'sTOY - my car is 5 years old and has 152,000 km on it, no chance
@ marcus - (1st pic)I cannot tell also if the yellow cap at the center is screwed or just pressed in. One thing is for sure, it is holding the blade such that it will rotate together with the shaft. - (2nd pic) at the bottom, there is black circular sticker, I opened it and saw only the other end of the shaft. - (2nd pic) there is one screw also at the bottom, I removed it and found that it only serves as hole cover. It doesn’t attach to anything inside the motor. Maybe it is for putting oil or something or maybe it is used for jamming the shaft but I am too afraid to do that and do not have the tool either. |
07-23-2011, 09:22 AM | #5 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Looking at mine, I have a feeling that you can't get it off without cracking the plastic. It appears that the tip piece is pressed on. Toyota doesn't show a separate part number in the EPC for the blower wheel or the retaining clip, so it looks like it is not intended to be removed.
07-23-2011, 09:40 AM | #6 |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
07-24-2011, 04:21 AM | #7 | |
I went to Toyota and ask for the price. 745 saudi riyals! (US$200!). I guess I'll just continue using my old blower 'til it stops turning. |
07-24-2011, 04:27 AM | #8 | |
Just a word of advice to those who are still under warranty: Listen to your blower motor. If you hear something unusual, take it to the dealer. |
12-14-2011, 02:22 AM | #9 |
OLD P/N : 87103-52140
NEW P/N : 87103-52141 I suggest that you just buy a used from the local scrapyard preferably from a 2011 model. New one from Dealer will cost you around ~$250 I tried to repair mine before by dismantling the motor and the fan unit but with worse result. I damaged the bushing assembly of the motor. The problem is that the motor bushing is is not a ball bearing type and just only plain brass bushing which will get loose especially when out of grease/lubricant. HiH |
12-14-2011, 03:56 AM | #10 | |
Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
+ 1 the local scrapyard should have alot of this... |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
A/C blower resistor | ubear7 | DIY / Maintenance / Service | 1 | 08-08-2010 09:53 PM |
A/c blower motor noise!!!! | LBdriver | General Yaris / Vitz Discussion | 28 | 09-12-2007 07:46 AM |
A/C blower | flighttekchris | DIY / Maintenance / Service | 5 | 08-25-2007 11:42 AM |
