ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
got the trd suspension installed...
but now the tops under the hood are sticking up about 1/2". it didn't do this on the stock suspension. i took my car to a performance shop here in dallas and the mechanic took the left side apart and examined it. he said there is nothing wrong with the way it is currently setup. i asked him if this was dangerous to leave it the way it is and he said most likely not. he said the new volkswagens also have the same setup where the tops stick up about 1/2" when the car is on the ground. he also mentioned working on a new 06 mercedes a couple of weeks with the same type of suspension design and it was also like this.
anyone else notice this? i have talked to another member on this forum and he said his is exactly the same way. i'm thinking maybe this is how the car was designed...? |
The tops of what?
How do they feel? |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I Drive a 129whp Yaris ;) |
ex-yaris owner
sorry guys. i mean the tops of the struts that stick up into the engine compartment under the hood that are held by the single nut on each side. with the stock struts, the tops were flush with the chasis. with the trd struts, the tops sit up about 1/2" from the chassis. the car feels fine and i don't hear any weird noises coming from the engine compartment.
ken at sparkstrd says i should not be driving the car. after talking to the mechanic at the performance shop it sounds like the car is perfectly fine to drive. just wondering if anyone else is in the same scenario... |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
by the "tops" are you refering to the strut mount, also know as a bearing plate? As far as I knew the upper strut mount is not changed when installing a lowered suspension, not even a TRD one.
Do you have the struts and springs, or just the springs? Springs alone should not change the top of the strut. TRD struts on the other hand, I don't know. You need to find someone on here with the TRD struts to compare.
ex-yaris owner
yeah i changed both the struts and the springs to trd.
black yaris, i'm talking about the very top of the struts where the dust cover fits onto. |
That's normal. Nothing to worry about, I can try to snap a picture of my setup later to show you it looks the same. Did you use an air gun to tighten both nuts (below and above the strut bearing)? If so, you should be good to go.
#9 | |
ex-yaris owner
at this point i am leaning towards what the mechanic said. basically the rubber bushing between the chassis and the top cap has all the weight on it. he even said the new volkswagens have the same exact design where the tops stick up about 1/2". this is so irritating. |
Can you take a picture of what you mean? it's really woth 1000 words
ex-yaris owner
yes, sorry. pictures really do tell most of the story.
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
I'm pretty sure mine stick up a bit too... I'll look when I'm home.
2006 Red Blitzed RS 5-door |
ex-yaris owner
#14 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
stole this pic from chris's diy spring change thread, but definetly stock cap does not sit like that....and with just lowering springs installed mine definetly dont look like that...might be a function of the new struts, but i definetly dont like how it looks....
#15 | |
ex-yaris owner
i'm gonna stop worrying about it. it's not healthy! |
#16 |
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
any one need to have an alignment after just the trd springs install?
web site (trdsparks thats selling them) says "The TRD Red Lowering Spring Set lowers the car 1.2” in both front and rear without changing the vehicle’s suspension geometry." Dose this mean you dont have to get an alignment? |
#17 | |
ex-yaris owner
#18 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| Fs: New Trd Stickers & Emblems !!!!! located in So cal | Trd86 | Items for Sale by private party | 13 | 06-25-2007 04:49 PM |
| TRD Parts | MC-BPT | Sponsors Classifieds Area | 9 | 06-23-2007 10:51 AM |
| PICS OF TRD INTAKE INSTALLED! | elsteverino889 | Performance Modifications | 9 | 03-03-2007 04:12 PM |
| What's the typical price, dealer installed, for the TRD lowering kit? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 01-17-2007 10:57 PM |
