![]() Drives: 2010 yaris Join Date: Jul 2011
I don't know what happened??
I have a 2010 yaris; today I left the ignition key on and the battery almost drained. There was still enough left that the presets on the radio and the clock was still correct. I used my boat bat. to jump start the car...Now I find that my ipod will not come on in the aux position (it did in the aux position before I let the battery go down). My car has a aux pig-tail in the glove box that plugs in to the ipod. Cds still work, I can plug a music player in to the aux jack by the break lever and it works through the aux. I seems that if the radio is on I can't get the ipod to work...But, when I disconnect the ipod and reconnect it, it will play until I switch back to the radio, then attempt to reconnect to the ipod it will not work, the aux button brings no results; nothing on the display either...What am I doing wrong?
Have you checked the fuses?
bring it into the dealer. it should be under warranty.
MY best guess is that when the battery drained down to its lowest point it messed up the programing in the radio. I disconnected the battery (after recharging) for 10 minutes; reconnected the battery and all worked as normal. Thanks for your input...73s... tom
| Tom Tom to provide embedded PND for Yaris | mehrit | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 07-05-2009 02:09 PM |
