Old 07-05-2006, 02:56 PM   #1
boxerboy
Drives: WRX ,Tacoma and Yaris
Throttle response
Has anyone noticed the throddle response lags a bit or is it just me?
boxerboy is offline   Reply With Quote
Old 07-05-2006, 05:21 PM   #2
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
do you have an auto or a 5spd? i have a 5spd and it's pretty good
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-05-2006, 06:38 PM   #3
boxerboy
I have a 5spd. The most recent cars I drive are 2002 WRX, 05 Mini Copper-S (wife's) and a 05 STI (son's). They are all M/T and the response of the throddle is snappy. When you snap the gas pedal down there is a couple of split seconds before it responds. It may be a qurik of the yaris.
Old 07-05-2006, 06:48 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Mines a slush box, and there's a slight lag, but its a 4 banger beater.. what do I care.
Old 07-06-2006, 01:23 PM   #5
Master2192
Drives: 98 Subaru Impreza 2.5RS
Thats crazy, as there have been lots of complaints about the Subaru STIs (all years) and Imprezas in 06. The Drive-By-Wire has huge lag. Thats if you know how to rev match and heel-toe, it makes it impossible to do smoothly.
Master2192 is offline   Reply With Quote
Old 07-06-2006, 08:12 PM   #6
boxerboy
Yea it is.
Old 07-05-2006, 05:30 PM   #7
Master2192
Aren't these cars Drive-By-Wire? That would explain the throttle lag.
Old 07-05-2006, 06:11 PM   #8
swng
swng's Avatar
Drives: 06 3-dr auto RS
Frankly, I don't feel any lag. May be the electrically controlled throttle can be adjusted by the dealership.
swng is offline   Reply With Quote
Old 07-05-2006, 10:03 PM   #9
dandj
Drives: 07 Yaris sedan auto
I have the sedan A/T and haven't noticed any lag whatsoever. I think it's a littie snappy, but I don't mash the throttle either.
dandj is offline   Reply With Quote
Old 07-06-2006, 07:25 AM   #10
jedi1701
jedi1701's Avatar
Drives: Yaris 2 LB
I thought it was me and it might still be but on my LB 5 speed it seems that on a dead stop take off it's alittle hard to feel the first bit of throtle push somethimes. I always like to take off with as little throtle as posible to keep from wearing the clutch and on the Yaris it never seems to feel the same, I am getting use to it but I really think that it does have a tiny bit of lag.
jedi1701 is offline   Reply With Quote
Old 07-06-2006, 07:40 AM   #11
fearturtle44
Drives: S Flint Mica
I have an AT and there is a little lag but all my previous AT cars also had the lag. You really have to be careful merging onto interstates with cars going 75 plus mph, it takes a little time for the Yaris to get "up to speed"....
Kevin
fearturtle44 is offline   Reply With Quote
Old 07-06-2006, 06:51 PM   #12
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Kevin
I think automactics by nature especially ones in this class are going to have "lag." It just a matter of mechanics and gearing and its an automactic, although they changing...
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 07-06-2006, 09:59 PM   #13
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
No, I don't notice any lag. But you really have to push the car into high revs to get the right shift point for quick acceleration.
Idjiit is offline   Reply With Quote
Old 07-07-2006, 01:14 AM   #14
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
Yeah... you have to plan your heel-toes WAAY earlier with throttle by wire... kinda sucks, makes me miss my aw11.
heylookitsjames is offline   Reply With Quote
Old 07-08-2006, 01:02 PM   #15
boxerboy
Hey try this with your yaris. With your trans is in netural and the engine runing stab the gas to the floor and release as quicly as possible, nothing will happen. Then you will know what I am talking about.
Old 07-08-2006, 11:28 PM   #16
swng
swng's Avatar
I have just tried it out. I do have had some response from the engine. So "nothing will happen" does not apply to my car. However, it is true that the engine needed a short while to really rev up. But note: just a very short while.
Old 09-13-2006, 11:57 AM   #17
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Me too.You know, in order to produce some result out of this thread, let's do this test.
In neutral(whether you have auto/manual transmission) press quickly the gas pedal to the end(until it reaches the ground) and release it immediately.Watch the revs and post them here.
I did that and it reaches simultaneously 2500rpm, which is very good, if we take into consideration that the gas is electric.
Old 09-13-2006, 11:38 AM   #18
daq421
MPG is the new cool
daq421's Avatar
Drives: 07 Yaris sedan (silver) Auto
Send a message via AIM to daq421
I have, in the last few days, really become aware of a heavy throttle lag. When I really hit the gas yesterday to avoid being creamed by another car there was a nervous moment when NOTHING happened and then the car finally took off. Today I tested the throttle response and found that a quick jab to the peddle will result in a fairly long lag. I don't know if this is by design or a design flaw but it's the first thing about the car that really blows. Not getting the gas when you need it is dangerous.
-Peter
daq421 is offline   Reply With Quote
New to Yaris ? Check in here !! VitzBoy General Yaris / Vitz Discussion 1960 02-02-2026 10:14 AM
